  • Replies 93
Posted Images
Haven't tried semi's (r-comp) yet.
595RSR 235 Front 255 Rear
A1RM pads
324mm front rotors
215rwkw
swaybars + greddy type s
camber bush
1.5 way KAAZ
I've done a 1.24.x there in October (?) last year. The only difference from the above with that time was PMu HC+ pads.
The setup now has cusco upper arm, 255 tires up front, 330mm ksport brakes and blue/yellow stuff pads. With an unknown diff (nismo/cusco 1.5).
So i would expect at least another 24 with the current setup. The aim would be consistent 24's.
Yeh well I've got some AO50's to drop on the car later in the year. I can tell you RSR are a good street spec tire and more consistent the KU36.
But they are still a good 2-4 seconds slower than AO50/RE55. Depending on the track.
Hi John,
I have looked at the Regs for the AROCA day and it says all competitors are now required to have their CAMS Officials Licence for at least the Flags Category? How do you obtain this?
Sorry I am new to the track day scene and hoping to have my car ready for this event and want to have all relevant Licence's. I have obtained my CAMS Level 2S.
Thanks in advance
Jamie
I have never had a problem and I don't have the flags license. L2S will be fine.
The flag guff is there from when no-one was turning up to be a flaggy for their days I imagine. What they do know is either employee flaggies
for the day or organise licensed flagies to assist and 'train' other AROCA club members to be flaggies.
the AO50's will automatically bump you up to modified class :devil:
Here is some action from last years FFCC at Sandown.
Nice footage John.
What camera setup are you using and also what are you using to display the gps track layout and speed?
Very interested in setting up something similar..
Cheers
i sent my entry form in twice and asked for payment details but haven't got a reply yet, i just thought they were full. who did you speak to?
Definitely can spectate.
Spoke to the organiser today and there is still room so I'm entering Monday.
    • Long time no see, I haven't posted since 14 years ago... To cut to the chase, R32 GTR. dead stock. Split wastegate hose = stock turbos were overboosting = front turbo's exhaust wheel has shattered. Have done a compression test following this and the results are (dry, cold) - 120 / 60 / 75 / 110 / 150 / 150. Haven't bothered with a wet test or leakdown test. The results definitely support front turbo failure (on 1-3) however the low compression on #4 is concerning too. Can anyone share their experience of when their turbine wheel shattered and damaged their motor - and what work needed to be done afterwards? Pistons? Rings? Valves? Throwing in the bin or salvageable? Motor is 100% stock. Will be getting it looked at further soon - I don't have a borescope and head hasn't come off (yet).
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
