  • Replies 93
Posted Images
Haven't tried semi's (r-comp) yet.
595RSR 235 Front 255 Rear
A1RM pads
324mm front rotors
215rwkw
swaybars + greddy type s
camber bush
1.5 way KAAZ
I've done a 1.24.x there in October (?) last year. The only difference from the above with that time was PMu HC+ pads.
The setup now has cusco upper arm, 255 tires up front, 330mm ksport brakes and blue/yellow stuff pads. With an unknown diff (nismo/cusco 1.5).
So i would expect at least another 24 with the current setup. The aim would be consistent 24's.
Yeh well I've got some AO50's to drop on the car later in the year. I can tell you RSR are a good street spec tire and more consistent the KU36.
But they are still a good 2-4 seconds slower than AO50/RE55. Depending on the track.
Hi John,
I have looked at the Regs for the AROCA day and it says all competitors are now required to have their CAMS Officials Licence for at least the Flags Category? How do you obtain this?
Sorry I am new to the track day scene and hoping to have my car ready for this event and want to have all relevant Licence's. I have obtained my CAMS Level 2S.
Thanks in advance
Jamie
I have never had a problem and I don't have the flags license. L2S will be fine.
The flag guff is there from when no-one was turning up to be a flaggy for their days I imagine. What they do know is either employee flaggies
for the day or organise licensed flagies to assist and 'train' other AROCA club members to be flaggies.
the AO50's will automatically bump you up to modified class :devil:
Here is some action from last years FFCC at Sandown.
Nice footage John.
What camera setup are you using and also what are you using to display the gps track layout and speed?
Very interested in setting up something similar..
Cheers
i sent my entry form in twice and asked for payment details but haven't got a reply yet, i just thought they were full. who did you speak to?
Definitely can spectate.
Spoke to the organiser today and there is still room so I'm entering Monday.
Guest
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
