Nice info about the ethanol sensor vipec combo disco. I would hope an any ethanol content Skyline could be engineered, ala Holden SAAB.How about fabbing a larger fuel tank, as per RT Charger, XW GT, mad max etc.
Edited by WHITE gtt
  • Replies 139
  On 21/04/2011 at 11:57 PM, HYPED6 said:
Now, I am still running the pistons that came with the car. From factory. Im making just shy of 600rwhp on 29 pound. My car had probably done 12,000 k in the last 18 months.
And for you playing at home, I have 1200cc Injectors and they are maxed at these power levels and mixtures.
What ECU are you doing all this on?
  On 22/04/2011 at 12:35 AM, discopotato03 said:
Actually I'm a twit , or similar sounding thing . What you could do is buy Caltex EFlex and test its Ethanol content and add the appropriate amount of say Ultimate 98 to make a consistant blend of something less than 70% ethanol . To end up with E50 shouldn't be to hard .
A .
Must have first coffee before posting ...
There is someone on here doing that that blends their own E42.5
Edited by Rolls
  On 22/04/2011 at 2:23 AM, N1GTR said:
Ive given up offering that suggestion a loooooong time ago
If you read my post, I refer to the tuner who was responsible for tuning the gtr I recently bought.
I.E. Sorry to disappoint you but crd did not tune this gtr...but he more than likely will, even though its a vipec
Don't get me started on dyno tuners, a very well known sau member was recently disappointed with your tuners results (name disclosed as I'm not here to defame others)
Same goes for every shop mate, thats life. Starting a thread about a tuners opinion, then not expecting the subject to come up? Come on, no one can be that silly
Agree to disagree :)
Anyway, if you decided to not run E85 then good for you, others have chosen to run E85 and good for them. Im going back to pump 98 personally not because there's anything wrong with E85, purely due to the range i need to get out of a tank on long drives through twisty roads on Sydney outskirts where even on pump fuel its pushing the economy pretty hard between servo's. Its annoying not being able to drive those roads with this fuel.
I'm sure if I used your tuner I wouldn't get the same service as what you do and vice versa...end of the day stick with who feels right and looks after you :)
Its like marriage haha
Way off topic sorry guys
  On 22/04/2011 at 5:54 AM, Birds said:
FYI Marko, to disclose something means to reveal it / make it known.
The joy of typing on blackberry with a mini screen, I left out "not to be"
Stevo - that's the other reason e85 is not for me as I also like to take long drives and will become stranded on e85
You could carry jerry cans of E85 for long trips or utilise a selectable unleaded petrol tune and carry a jerry can of unleaded that will get you to a service station?
  On 22/04/2011 at 2:32 AM, NYTSKY said:
http://www.zeitronix.com/Products/ECA/ECA.shtml
Awesome bit of gear available from Just Engine Management.
That is truly awesome. Even if my engine management won't utilise the sensor, I think I'll buy one just to keep an eye on ethanol content so I can adjust it to always be E70. I thought these sensors would be intank, but here we have an external mount with a simple hose in / hose out connection you could mount anywhere along the fuel lines. Then an easy plug straight to the LED display. Win. Do you think it would be best to tap into fuel return or fuel supply? Or would not matter too much?
Marko, I hate to be picky, but I will... you also did the same thing in your opening post. :D. Must be an inherent anomaly with the Blackberry. I'd get it checked. :nyaanyaa:
PS, withheld would be a better word :D
PSS, I am keen to try E85 when I finally get my car finished.
few guys over here in WA doing it, thanks to ethanol being illegal at the pump here and no fuel companies showing any interest in shipping it here. we have to buy drums of csr stuff, which is over $2/L so using half that and half 98 makes it a little more affordable
Edited by JonnoHR31
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
