Today after driving the R34 GT manual not pushing it very hard, after the ignition, the yellow check engine light symbol came up and stayed up on the dash. When I stopped the car about 3 minutes later, the car was vibrating quite a fair bit, so I went to check the exhaust, and it was making this sound "chug chug chug chug" blowing hot air out unsmoothly. No other sounds out of the ordinary were heard. After an hour I turned the car back on and thrashed it a little to see if the yellow light would come on again, but this time everything was normal and nothing weird happened. I checked the radiator and that was all normal, what could it be? Coilpacks? Plus, I don't have any diagnosing tools for my car.... This is the first time this has happened in the 1 and a half months since I've had the car.
https://www.sau.com.au/forums/topic/361692-check-engine-light/
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
