Rb26 Rising Temp - Advice
Just completed a re-build:
JE 87mm pistons
Tomei OGK - 1.2mm
ARP Head studs
Cosworth Bearings - Std
Tomei Poncams - 260/260
Apexi PFC - D Jetro
Koyo 4 core Radiator
N1 oil pump
Mishimoto 62c Thermostat
GT2860-5 Turbos
Mines Titanium DP
3.5" SS Jasma Exhaust
Car runs well and maintains water temp in the 70s and oil temp in the 80s when driving.
Problem is when idling for more than 10mins, water temp rises to 90c+. If the car is parked soon after, about 200ml of coolant flows out of the expansion tank.
Advice?
you might have a basic water pump issue or some sort of flow issue
90 isnt that bad, but it shouldnt move past 90
ask the engine builder?
the n1 water pump flows less at idle vs stock as its designed for high end RPM high flow
so at idle, it will actually be outperformed by the std water pump in terms of flow
when did this start? since the radiator change?
check the basics etc
Would an N1 water pump help?
not really.
You've gone a put a part in thats not fit for the application - a 4-core rad.
As you've stated it's perfectly fine when driving, and it will be... Or more importantly track - which is what i'll guess it's designed for. Not street.
I could be wrong, but all bets point to the rad as the issue.
You might have not bled it correctly or something and have air lock/bubbles. But i doubt it.
I built the engine myself and it definitely goes past 90, but if I keep the revs up above 2k, it drops slightly.
The problem started after the re-build which is the same time I installed the new rad.
Already bled the system twice. No change.
Is it a 53 mm koyo radiator? If it is I have the same on my r33 gtr
I have never had a problem like this, normal driving temp is at 66 deg n when at idle in traffic it may only move 1 or 2 degrees
You have a 62 deg thermostat but the temps are in the 70s when driving.
Something seriously wrong there...and why so cold?
even 70 degrees is too cold for a production engine, should be up near 80
Thermostat only determines when the water starts circulating. Once it is open it has no effect on max temps (only minumum temps in a very cold climate). Stock would be better as 70deg is not hot enough. Have you got a shroud for your fan? Fan doesn't do much without one.
  • 4 weeks later...
 Share
    • I think throwing the hydraulic power steering system into the trash and converting to electric power steering, e.g. Astra PS pump would solve many issues.
    • so finally had an event i was home for that didn't get rained off or otherwise cancelled to be able to actually drive the car, unfortunately was roll racing which isnt my favourite thing ever but had an awesome night with friends and testing the car out. obviously a huge difference in driving experience with the samsonas although still without flat foot upshifts the ratios are so much nicer and actually has boost into the next gear which was not something i always experienced with the stock gearbox. but of course absolutely loving the sound of the sidepipe and for its downfalls of ruining the car in ever other way it does sound awesome at the track.   had some weird issues where it would misfire in 2nd but fine in every other gear and at the end of the night at the end of the run would have no throttle until it decided it wanted to work, so will be looking into that before a proper track night coming up in just over a week to really see the changes in the car. Messenger_creation_C9B7F84E-0820-444B-A53D-9AD40F7DDC5B.mp4     received_870009858147161.mp4   Messenger_creation_046B1D12-ABA0-4B01-B78F-262559E64ADC.mp4  by the end of the night found that if i was nice and gentle on the throttle in 2nd it wouldnt misfire so was only fully throttle and loaded up in 2nd it would occur
    • I think I will try out Frenchy’s power steering kit. Looks like a better solution.
    • Useless lot aren't they? Releasing stuff on the market that doesn't do what it's supposed to do without you stuffing about with it and spacing out the spacer lol. FFS.
    • Similar experience with Ross pulley. Can't recommend.
