Hey Guys
Just had a set of Vertini Mclaren black lip 20s fitted to my stock V35 now i need to decide to drop it like its hot or not. Tell me what u think
Cue Cobey....
Im sure cobey will chime in here, he has 20s and SLAMMED! Looks great !
yup lower it. A 350z spring/shocks setup will drop you around 30mm which will give you a good stance and can either be cheap or exy depending on the components you use.
The 350Z nismo suspension is another option for a little more than a cheap springs/shocks setup.
Coilovers will get you "slammed" but will not be cheap to do it properly
DROP IT!
You will never regret it when you get thumbs up everywhere you go... and I've never been pulled over for ride height....
I'm currently at last measure stilling at 77mm at the lowest point.
BC coilovers are a great investment... drop or raise at your desire!
DROP IT!
I'm with this guy, even though he's kinda gay ;)
Although when it's slammed and you want to go to the shops with massive speed bumps, you kinda wish your car was 4x4 spec lol
Or just be like me and avoid going to the shops altogether haha
  • 3 weeks later...
Y not the GTR kit, i love the look of the front bar
because there are Gt-Rs out there.
I guess it's all about personal opinion.
But some people on other skyline forum seems to laugh at the body kit. Because they believe that whoever buys the GT-R kit is a GT-R wannabe...
No personal offence, just sharing what's on other forums.
The front bumper is more aggressive though :)
Yeh im not getting it cauz i want a GTR (well who doesnt want a GTR but anyways) i just love the style of the mesh grills in the front and rear bar im not going to badge it as a GTR if i do get one, but im looking at all these pics and the paint matching is making want to cry i have seen some horrific paint jobs and its making think i should keep it stock lower it and turn it into a sleeper. If i was to put a turbo kit in it later on what sort of suspension should i be looking at to be able to cope with the increase of power?
I guess it's just different people have different opinions.
To tell the truth, I also thought of putting on this GT-R styled body kit before too. But after more research, I opted to go with a clean look that is not too expensive and keep the stock look of the V35 coupe. :)
Honestly i think every v35 owner goes through this once they get their ride. As you did, we do a bit of research and come across the hoards of tolls saying how ricer it is and get turned off ><. Also its expensive + the car is my daily which was the main turn off for me.
In Australia i think it is extremely unique to have the gtr or the aston martin body kit and you will always get compliments from everyone. Its those few car enthusiasts who think anything modified is ricer and if they dont approve of it then its shit.
whatever kit u decide on, lower the car first. last thing you wanna have is a kitted car with off-roader style wheel gap.
be prepared to sacrifice going to places with high speed bumps, steep inclines and mates houses with big curbs. i'm just mildly lowered (1.25 inches) and the front bumper and diff protector skid plate scrapes on most ramps.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
