  • Replies 163
Sort of used to live around that area, know the showgrounds which is basically opposite where we are going, I think.... pretty easy to get there though:
If you guys want me to take pic down just yell out!
Uhm... I wouldn't go to that meeting spot if I were you. There's been trouble there in the past with hoons and it's a pretty well known meeting spot.
Maybe choose somewhere different?
you refering to the final destination or meeting spot for both brisbane crew and GC crew to meet up?
Why all the Pm's if the meeting point and even a map are gonna be whacked up like that?
just following the tradition. if you guys want, i can post it up for ALL to see.
i believe the aim of thursday nite cruises was to avoid hassles from the police but i do think they have caught onto the thursday cruisers now
Yes I wondered about that, as a speed camera was placed conveniently at the entrance of BP Yatala last week :D
:werd: on that trap at yatala... very convienient... I've never seen a camera that far OFF the road... EVER
Is the meeting place the same as the latest PM genisis?
SKa, il meet at yatala, let me know what time...
Im up for a good night, works been a bitch, im over it all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Any jobs at umart chris??? lmao.
Check this :D under the "Be afraid !!! be very afraid" post ... congratulations for both of you, but looks like Strutto needs some help with his spelling......
http://www.skylinesaustralia.com/forums/sh...88&page=2&pp=25
go down to the last thread. Hey, i might join as a moderator to check on the moderators spelling and grammar......hihihihi...... :P
Seriously I have several freinds who are police and they all deny any knowledge of anyone viewing forums (As they probably would do even if they knew or not) and then going and raping meets, but also they are fairly low down in the scheme of things, but having conversations with them tend me to think that you guys are just paranoid.
BUT there are a lot of people here with a hellofa lot more experence with these things so I agree it is better to be safe than sorry, just never heard of anything like that happening, only rumours and heresay so I dont want to find out through experiencing it happening.
Sorry bout the pic, thought it would be fine to post the starting meeting place, my bad anyway I'll just shutup now and follow the leader :P
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
