Hey everyone, car is tuned now .. everything seems to be going ok except for the water temp.. i have let it get as high as 98 degrees...i went and bought some of that "redline water wetter" yesterday. the $50 stuff.. and it seems to keep it lower until i get up the car for a bit..
now i think i know what the problem is.. just wanted other ppls opinions ... the guy that wired my ecu, wired the fans onto the wrong output, so the tuner could only have them "on" or "off".. so thats the way they are atm, allways on...
would this block airflow at high speed? i suspect it would? as the fans are on the front of the radiator as they would not fit in the engine bay..
s13 with r34 rb26
mspec alloy radiator
cant remember model numbers but, they highest powered 11" spal pushers i could buy from pwr
thanx
thermostat is brand new, though im not sure wat temp it is, just bought one from global... might try a low temp one...
and to titan: u wouldn't think that 100kph air would be better then what the thermos push? im not sure if wind would get through the thermos without to much turbulence? ..
From most I've seen smallish paired elec fans don't cut it . The successfull method I reckon is to use one large fan even if its diameter is slightly greater than the height of the radiator core .
As for triggering the fans many tend to forget that the water temp in the RADIATOR is critical and must be lower than what you want to run the engine at to regulate properly .
Its the engines thermostat thats intended to set the engines lowest temperature not heighest so provided the radiator can keep the water in it cooler than the thermostats opening temperature the system will regulate temperature properly .
If your cooling systems capacity is a bit lacking then the best you can do is to run the fan/s all the time or have a thermo switch located in the radiator set low . Remember its the reserve of cool water in the radiator that allows engine cooling when the water thermostat opens right up . If the rad water temp is high then the hotter water can't cool the engine can it .
A six cylinder in an engine bay designed for a four is always a drama because theres no room for a clutch fan and the cramped bay often gives a poor flow path for the hot post radiator air . All the huge radiators in the world make little difference in these situations because if air banks up in the bay it won't flow well through the core resulting in poor heat transfer .
IMO same old same old , RWD R32 better platform for any RB engine than a Silvia and the better big capacity route for an S13/14 is the KA24DE engine like Nissan used in USDM S13/14's . Better fit , better cooling , better weight distribution , heaps of turbo conversion gear available in the US - and its all a known quantity .
Bottom line is a Silvia is not a baby Skyline and there are no factory solutions to this six into four hybrid .
A .
fwiw i have a rb25 in my s14 and i managed to fit the clutch fan in there. engine mounts were modified tho to move engine back and lower by 25mm in each direction. i used an R31 fan hub which is the shortest of all nissan hubs. it all fits tho.. but only with a stock rad and shroud. which i seem to have solved my cooling issues with instead of using the shitty ISC rad with no shroud (wouldnt fit)
hmmm so by the looks of things its pretty f**ked haha... i might just get the fans rewired and see if anything changes... i take it every silvia owner with a 6 cylinder has overheating issues? would spacign the bonnet help?? any other things to try?
Lifting the rear of the bonnet makes it worse 99% of the time, creates a high pressure area at the rear of the engine bay and makes airflow worse.
I would dissconnect 1 fan and go for a drive, might help with airflow through the radiator when driving.
Oh BTW do you still have a/c?
There pretty small fans 11's. On my 31 i ran a 14 and a 10 on a 52mm alloy rad and it was only just up to scratch with cooling, even then in summer it couldn't cool down the motor below 85c.
If you have room run a standard viscous fan with a shroud. I learnt the hard way the thermos are generally pretty crap.
Are your fans front or rear mounted? If there mounted in front of the rad i would put them behind and have them pull the air through, pushing it through isnt the best setup.
Also a proper fan shroud around the fans would help alot, you'd be surprised how much the shroud actually does in directing the air through, i think thats why my old setup wasnt that great.
2 11" fans where the only ones i could fit.. couldent fit 1 16"... they are the most powerfull 11" blowers spal make...or so pwr told me.. they are mounted on the front of the rad.. there wasnt even enough room in the engine bay for the spal slimline ones...so deff no viscous fan... i have 38mm from rad to pulleys... so its pretty tight in there...
^^^ you wouldn't be the first! fans are normally set up to suck air through the radiator so if you have them on the front has the direction been reversed? No aircond should be a help. And shrouds are a must even if you have to custom make them. And fit a thermo switch - its not too hard. Also get an air diverter if you haven't got one already.
Exactly...easy enough to get wrong and even easier to correct!
Get a piece of paper and place it on the engine side of the radiator core...if it sticks, your fans are going the wrong way!
As has been said above, shrouding is a must, I've managed to get a single 16'' fan in the original 32 GTR shroud, got this working in conjunction with the air con fan...also have a diversion plate...all seems to work well.
fans are deff blowing :)... but since the fans are on the front of the rad.. wouldent it be worse to have a shroud? coz then no other air besides wat the fans are pushing in could get through...
and Kiwir24t.. what is a air diverter? i have a bit inbetween the headlights, is it that?? hmm ill post a pic
EDIT: ths bit behind the grill****
Edited by BrynDETT
Yes, that is an air diverter. In most cases a lot more can be done for engine cooling...
Make some custom ducting so all air coming in through the front bar can ONLY go THROUGH the intercooler & radiator, not around it at all. So loke a divertor but top, bottom & sides...
If necessary use foam beside the rad to get the best seal you can
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
