My car also has the same issue as OP, when starting on cold start in mornings(stock ecu) the car will start to about 1krpm and then die if I do not blip the throttle for a split second. Something seems sticky... Its like something isn't opening up when it should be.
I don't really understand the logic behind the water temp sensor causing the issue... If it was f**ked, a rev will not fix it. My temp gauge is working just fine so that gets ruled out I guess.
When I get it tuned, ill get the tuner to check it over and clean any shit thats cleanable.
Interestingly enough though, back when I was running a power FC it never did this. Always started perfectly. Going back to stock ecu(had stock, went pfc, now stock but going back to pfc soon), the problem came back.
Edited by SargeRX8
Probably? it is definitely true.. there are two separate sensors, one for ECU and one for gauge.
Does it fix itself the instant you rev it? or are you giving it a few revs (and thus could be a time based thing)?
If the ECU temp sensor is fkd, after a short while the ECU will just assume the engine is up to temp and normal driving can ensue.
OP: is your R33 a Series 1.5 or Series 2? I have a red coolant temp sensor as well my part number on the sensor is....
A27-611
L00
This part number on the sensor does not seem to relate to any nissan part number in FAST but it does say JECS on the sensor and had the nissan symbol
Edited by DJSimmo
  • 1 year later...
i know this is years old, but does anyone else know for sure whats an option to replace the cts sensor in an r33 gtst?
will this one work?
http://www.ebay.com.au/itm/New-Genuine-INTERMOTOR-Nissan-Skyline-R33-GT-R-Coolant-Temperature-Sensor-/121056444459?pt=AU_Car_Parts_Accessories&hash=item1c2f86c02b
its says nearly every other nissan except gtst :wacko:
also i am gonna ask the seller, just cant remember my login and password atm
Edited by MatthewT85
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
