  • Replies 204
Thanks gregor for the tips. On last check my tyres were 36 psi so I take it the global advice would be to drop this figure to close to 30 all round, to be checked after the first session.
I'm going to print a "don't use the handbrake" sign - that's one habit it is going to be hard to break.
So, anyone driving down at 5:30am on Sat morning??
I am leaving Campbelltown around 5am if you can manage that. Me = slow driver.
wow..too early for me to manage. with a bit of luck i will be coming thru Campbelltown by 5:30. Even at 'slow' surely it's only 1h 45m from C'town?
I'll have to disagree with gregor... I found a higher tyre pressure on street tyres works well as street tyres do not have as reinforced sidewalls as semi slicks. This should reduce tyre wall flex which is important as you are going to be a lot harder on your tyre's sidewalls than if you were on the street.
I haven't used street tyres on my Skyline for a while now, but when I did I kept my tyre pressures around the 36psi cold mark, then at the track bump them up to around 38-40. After a session I would set them at around 41-42psi hot... but that was when they were well and truly overheated and didn't want to grip the track anymore and you want to avoid doing this too much as it degrades the rubber. This may seem high, but my tyre wear was still consistent with under inflation (and/or someone who uses the steering wheel as a brake of sorts :blush:)
My previous comment still stands, focus on getting consistent (not to be confused with fast) lap times before trying to change too much with the car ;)
EDIT
Asking about tyre pressures is relatable to asking how long a peice of string is :laugh:
I dont think our approaches are too different but perhaps i wasnt as clear as I intended. When I go to the track I usually stay at goulburn the night before and if possible trailer my car - as a result the tyres are cold or at least cool by the time the first session rolls around. If you run pressures in the mid 30s cold for normal use then you can expect them to shoot up more so than when street driving when you hit the track. 10 psi was probably an over statement but taking off 5 psi cold would help get you towards the 41-42 psi hot target you mentioned. With normal street pressures (36 in my xr6t) i found the car was very slippery and that the pressures had gone up alot.
So for the guy who asked - keep an eye on your pressures after each session and adjust if you think its needed.
Sound advice, thank you. Just out of interest, will there be people with air compressors willing to share with us noobs so we can pump our tyres if needed?
That's just how I roll :P
There is one at Wakefield, but it isn't very good... if I remember to bring mine I'll let you borrow it ;)
ahaha because race car indeed!
weather looks great for turbos....sunny and 10.
I'm not running the race car this time, but I will be available for anyone who wants some pointers on track driving - I will be near the flag point so just grab me.
yeah its a bit of a pain but I just don't have the space to fix it while i am building the house. Pretty sure tk80 is out too....cage is half finished :(
On the good side dnissi will be there to keep them honest....he was only a tenth behind me all day and I'm sure will be looking to go faster this time.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
