Im out :rant: , my timing belt tensioner just failed. I'm unable to get a refund so if anyone wants a spot pm me or call 0434072251
We had a similar problem with numbers last event too. Matt did a post on the Renew site but didn't get any response at all.
I plan to discuss this at the SAU General Meeting as the photographers do such a great job, but asking them to spend 3 days doing photos for very little isn't a fair deal. I will try to propose a few alternatives to the club so that we can retain their awesome services.
But this time we will be sans SAU club photography.
Be sure to come to the AGM to voice your opinion on our options.
  • Replies 204
that sucks :(
Anyone still wanting to come along give Steveo a call ....with this spot I there are either 2 or 3 still available. Or if you feel brave just come along....
Best time for the day ? What car ?
SAU WINS thanks to Greg.
http://www.natsoft.com.au/cgi-bin/results.cgi?28/05/2011.WAKE.S3.Y
Seems we didn't need my space frame dangerous car.
Nice work Stretch.
Cheers
Neil.
Congrats SAU!! Looks like some super fast times from both SAU and RENEW.
I'm sure i can speak on behalf of Matt also, sorry we could not make it down today guys. We love you all but expense wise i am broke ($1400 for a new clutch/ clutch change in my evo) and as i live in manly it's a good 3 hour drive, long day walking around, 3-4 days of retouching and editing and for what would of been something like $40, it just didn't seem viable.
I believe we are actually helping you guys out by doing such great deals on photos (normally charge $50 a disc) that are not just simple amateur photos but photos that are on par with magazine type photos.
We love coming down and having a chat and of course it's not all about the money, but at the minimum, travel costs need to be covered.
I hope that next track day we can gain some more interest!
We will both be at texi as it's a lot more local so if you want to have a chat just come up to me or Matt (Matts the ugly one!!!!).
just like to thank the SAU and RENEW boys who organised today, top job as usual!
everything ran really smooth. but next time, could you do something about the fog??:nyaanyaa:
Great run day, thanks to RENEW & SAU members that organised it!
Funny the top 4 SAU cars are not Skylines one was even a Mazda buts it’s ok Neil I still support SAU driving an old rotor , where are all the fast Skylines hiding?
That S15's an ANIMAL!
Kory you are soooooo right. I tried to take a couple of photos between video and well, most of mine simply turn out rubbish compared to you guys. We'll be discussing at the AGM to try and sort out an equitable arrangement so that we can continue to enjoy you and Matt's work.
Condolences to the poor yellow Mazda. I saw him walk away but does anyone know him / know if he's alright?
Yeah he was helping clean up when we were cleaning up the fluids off the track. He will probably be a bit sore tomorrow. From what I saw of it earlier it seemed to have a lot of body roll, hope they got home ok
Gregs S15 is great, just needs that rear diffuser finished and it will look so damn awesome
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
