None of you saw this by any chance? :D
Woman arrested after #police pursuit – Goulburn
by NSW Police Force on Saturday, May 28, 2011 at 11:37pm
A woman has been arrested and is expected to be charged under Skye’s Law following a pursuit in the Southern Highlands this afternoon.
About 4.45pm, Mittagong Highway Patrol officers conducting speed checks on the Hume Highway at Berrima detected a green Mitsubishi travelling south at an alleged speed of 139km/h in a 110km/h zone.
When police caught up with the vehicle, it failed to stop and a pursuit was initiated over a distance of 60 km and reaching speeds of 160 km/h.
It will be alleged that at one stage, the pursuit entered an 80km/h work zone, with the offender driving through it at 135 km/h.
Police sought authorisation to use road spikes in an attempt to stop to vehicle. These were successfully deployed about 10 km north of Goulburn.
The sole occupant of the vehicle, a 36-year-old woman from Queensland, was arrested. She is currently being assessed in hospital, after which she is expected to be charged with police pursuit – not stop – drive dangerously (section 51B Crime Act Skye’s Law), exceed speed and drive speed dangerous.
  • Replies 204
A woman has been arrested and is expected to be charged under Skye's Law following a pursuit in the Southern Highlands this afternoon.
The sole occupant of the vehicle, a 36-year-old woman from Queensland, was arrested. She is currently being assessed in hospital, after which she is expected to be charged with police pursuit – not stop – drive dangerously (section 51B Crime Act Skye's Law), exceed speed and drive speed dangerous.
Yes saw all the action on the way home, had two police cars come past me travelling up to Sydney doing well over 160kph, another 4 mins up the road they were set up on the other side of the road with the spikes ready to deploy sitting on the cop car bonnet. Would have gone another 3 mins up the road and could just see in between the trees in the middle of the road a car flash by with cop car and sirens going as well. Wanted to go back to watch all the action would have been a good show.
When I drive past they had the woman on the ground out of the car in one of the turn around areas. There were about 5 police cars parked there too.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
