Hi everyone, clearing a few left over items.
1. R33 Series 1 Spoiler in Grey with Brake LED - $100
2. R33 Series 2 Spoiler in White with Brake LED - $110
3. R33 S2 Dash Clock - $20
4. 180sx SR20DET RedTop HKS Pod Filter and Induction Pipe - $50
5. T25g Turbo (needs rebuid) - $70
6. Momo Steering wheel with 180sx boss kit and horn button and Stock N14 steering wheel - $90 or $50 each
7. 03 Nissan 350z LHS tail light (slight surface crack, no leaks), perfect for mods - $70
8. LED Amber Interior Lights - $20 for all 4
9. Manual Gear knob and e-brake cover ( 4 x e-brake cover and 2 x gear knobs) - $90 for all or $20 for gear knob and $15 for e-brake cover
10. XForce cannon 2.5" to 4" tip?. Off VL but can be modified to suit other cars - $110
11. 2 x Steel Wheels and tyres. Some Thread left. Good for trailer or spare. Has been primed but not painted, so buyer can paint any colour they want.
Regal
Sport Comfort 400
205/65/R15
Pickup from Berwick or can post a few items together at buyers expense.
dsc00464f.jpgdsc00463f.jpg1807132011041225tmb1.jpg1774072011031508.jpg1774052011031506.jpg1807122011041241tmb1.jpg1807452011041632tmb1.jpg1807452011041653tmb1.jpg1807372011041532tmb1.jpgdsc00517be.jpgdsc00518yg.jpgdsc00467kz.jpg1814992011041346tmb1.jpg1814992011041322tmb1.jpg1814992011041305tmb1.jpg
https://www.sau.com.au/forums/topic/361791-r33-180sx-350z-plus-more-parts/
im keen on the momo steering wheel, can i get some close up pics of it champ please?
you can email them or mms them - [email protected] - 0435 430 440
cheers!
cheers!
Pm'd
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
