hi.i have r33gts fitted with the rb20e.i would like to knw can i run the rb30e on the rb20e ecu with a piggyback to sort out the fuelling and ignition.just want abit of more power for now to move the heavy body.will the rb30 bolt straight in using the stock rb20 engine mounts.
https://www.sau.com.au/forums/topic/361822-rb20e-to-rb30e-in-a-r33gts/
forgot to mention im from south africa.want to do a rb25/30 at a latre stage.whats the difference between a r33 rb25de and arb25de neo.from what i've read the neo got smaller combustion chambers then the r33 rb25de so the comp should be high enough if you use the rb25 neo pistons
was thinking of doing that.how hard is it to fit a vh45 in a r33.i've read john's thread bt it dnt say if he had to mod a few things to fit it n most info u get is how to fit it into 300 zx n s13/14s n not much into skylines
It would be a pretty similar affair. Should be easier than a Silvia I would think as the bay would be bigger to start with.
should be an awesome car seeing what john done with his one but back to topic can my rb20e ecu run a rb30e.i'll be using everything on the rb20,inlet manifold,injectors,dissy and the exhaust manifold.i think it would run fine.im mostly after the extra touque of the rb30 till i upgrade later.
i think it should cz the rb30 in south african r31s ran with 21 deg timing.dnt knw if the injectors are the same size.it mite pick up a few extra kw cz the r33 rb20 inlet manifold seem to have bigger runners then the rb 30
Ive got an rb30e in my r33 and it smashes the pants off rb25de`s
the torque is good. Not so great on fuel tho
Engine mounts will be the same as the difference is in the block height
in terms of managment its best to use an rb30e loom and re wire it to suit the r33
Ebay has some cheap turbo kita for rb30e`s if u wanted more power later on
if u are serious pm me and ill send u some pics of my conversion and the wiring
contact nistune in australia who will be able to "chip" your rb20e ecu to run different fuel and timing maps to suit the rb30e.
my rb30 is n.a
basic mods: GTS style extractors 6-2-1, 2.5inch cat back zorst, pod filter, advanced ignition timing running premium fuel.
car has a 4.46:1 LSD, that helps ^.^ i dragged off a WRX to 100 km/h the other night
the car realistically has around 100 rwkw, with a cheap turbo kit it would have close to 170 rwkw
nice.im from south africa so my best bet will be to get a dastek piggyback ecu.currently got a pod n 57mm straight through exhaust with a rear can box.im making 85kw on da wheels.my best 1/4 mile is a 17.5 lol.with 100 on da wheels n more torque i mite get in the 16s
skit it will be hard for me to get the parts.i will be upgrading to a rb30det at a later stage just want sum extra power to move the heavy body.chris how high do u revyour rb30.seeing as the rb20e has a higher rev limiter i'll to let the piggyback ecu limit it to 6100rpm
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
