hi guys
unfortunately i have to sell my skyline.
93 r32 gtst type m
its unfinished i started putting wide rear guards on it. motor is in good condition it has r43 rb25 turbo, gtr injectors, z32 airflow meter, sard adjustable fuel reg, front mout intercooler,3 inch turbo back exhaust,nistune ecu, adjustable front camber and caster, 17 inch wheels,gtr front bar needs fixing, type m sideskirts and rear pods, gtr spoiler, aftermarked steering wheel.
thats all i can think of body needs a little more work to be finished. has no rego
$4500
also have an r32 gtst rolling shell. has wide vented front guards sunroof standard r33 wheels,3 inch exhaust
front window is smashed, all other windows have been removed but will come with the car
$1000
or take both for $500
pm me on here or shoot me a text on: 0414624460 and ill call you back
located in st clair sydney ill get some pics over the weekend
cheers troy.
https://www.sau.com.au/forums/topic/361850-r32-gtst/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
