Make: Nissan
Model: Skyline GTS25t Series 1.5
Year: 1995
Engine: Series 2 RB25DET
Mileage 109,000KM
Gearbox: 5 Speed
Contact Details: PM for Phone Number or Reply Here
Price and Payment Conditions: $12,000
1995 Nissan Skyline R33 GTS25t Series 1.5
Engine:
Series 2 RB25DET
RB25 Turbo
CP Forged Pistons
Shot Peened Rods
1.2mm Metal Head Gasket
Gates Racing Timing Belt
Genuine Nissan Timing Belt Tensioners
Genuine Nissan Water Pump & Thermostat
Genuine Nissan O2 Sensor
Split Fire Coils
Nismo Engine Mounts
Motul Turbolight 4100 10W40 Engine Oil
Turbosmart T Bleeder on 8PSI
HKS Pod Filter with Metal Intake Pipe
Exhaust:
Spilt Dump & Front Pipe
Hi Flow Metal Cat
Straight Through 3 Inch Cat Back to Diff
Twin 3 Inch Stainless Pipes from Diff
Gearbox/Driveline:
RB25DET 5 Speed Manual
Nismo Lightweight Flywheel
Nismo 3 Puk Clutch
Nismo Gearbox Mount
Braided Clutch Line
Redline Shockproof Gearbox Oil
Shimmed Diff
Penrite 85W140 Diff Oil
Standard Tailshaft & Driveshafts
Brakes:
New Bendix CT Pads Front & Rear
New RDA Rotors Front & Rear
Braided Brake Lines
Wheels/Tyres:
Front: Work Rezax 17x8 +5 Marshall 205/40R17
Rear: Work Rezax 17x9 +5 Kumho KU31 215/45R17
Suspension:
Pedders Extreme Coilovers, Adjustable Hieght & Damper, 8KG Front & 6KG Rear Spring Rates
Whiteline Adjustable 27mm Front Swaybar With Pillowball Links
Whiteline Adjustable 22mm Rear Swaybar
ISC Castor arms
ISC Front Camber Arms
ISC Rear Camber Arms
ISC Hicas Lock Bar
KKR Traction Arms
KKR Tie-Rod Ends
Alloy Rear Subframe Pineapples
Extra Lock Spacers in Rack
Super Pro Rack Bushes
GTR Front Strut Brace
GTR Rear Strut Brace
Cooling:
Alloy Radiator
Genuine Nissan Radiator & Heater Hoses
Greddy LS Intercooler Kit
Interior:
JVC Double DIN Headunit
JVC Front & Rear 6.5 Inch Speakers
R33 GTR Front Seats
Exterior:
Genuine Final Konnexion Kit
Origin Roof Wing
Nismo Clear Side Markers
Sedan Headlights & Grille
Other:
Motor was put in about <1500KM ago. All Fluids, Belts, Hoses, Filters, Spark Plugs ect. done at same time. Paint isn't that good in places and is the only downfall of the car. Apart from that could'nt ask for a better car!
https://www.sau.com.au/forums/topic/361864-s15-r33-gtst/
  • 1 month later...
  • 1 month later...
  • 5 weeks later...
Bump guys. Car is still here. It is now running shadow black chrome enkie rpf1 wheels. 17x9.5 +15 on front and 18x10.5 +18 on rear. These wheels can come with the car for extra.
https://www.sau.com.au/forums/topic/361864-s15-r33-gtst/#findComment-5969918
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
