  • 4 weeks later...
Mitchell's Pass Rd from Blaxland down to Emu Plains has just been reopened since the rockfall of 2009 :)
And they've made it a 40km/h zone.
I could now get busted for speeding on my pushbike.
Well, at least down to Lennox Bridge, one has to scan the speedo...
I don't trust the constabulary not to set up a sneaky trap at the sweeping righthander at the bottom.
At least it's open though, can't complain too much.
  • 1 month later...
Hi all
First great drive is from Thredbo to Khancoban along the Alpine Way then about 5ks after Khancoban turn right up to Cabramurra, through Kiandra and then a high speed drive to Cooma.
Second is from Dungog to the Buckets Way, turn left to Gloucester and on to Walcha along Thunderbolts way, across to Dorrigo then Waterfalls Way down to the coast via Belligen.
Third, The Putty road from Bulga to the halfway house and back.
But the ultimate is Targa Tasmania.
Safety Fast please.
Thanks, good info...
A few of us on the Chocolate Cruise did the Mtchell's Pass loop yesterday.
Nice short ONE WAY strip from the bridge to the carpark at the bottom. No speed signs by Penrith Council or Dept of Roads up yet in that section yet.
  • 2 months later...
Terry, my neighbours grandson has only had his licence for a few months, drives a hyundai getz and is no way a car enthusiast or lead foot driver got pulled over at the bottom of mitchells pass at the carpark area and was done for doing 60 something in an alleged 40 zone, i never do 40 on my bianchi down there, but then again i dont want to add wear and tear to my brakes. i took the liberty down the other day and tried to do 40 down the second section it was difficult, may i say near impossible. so unfortunately i just avoid driving the car down there now. :unsure:
Police cannot plant themselves on those bends of Mitchell's Pass as you can patently tell.
They'd have to be in the carpark and by the time we come to the last bend, we've slowed down!
He must have got pinged for entering the carpark too quickly!
I've heard that the rozzers have been walking up from the old GWH (behind the locked gate) below the straight section, and getting people with a handheld gun coming down to the left hander just before the final straight section. They then pull you up as you exit onto the GWH.
As has been mentioned; it's now a 40 km/h zone & since it has been closed & reopened, I've noticed a lot more cyclists riding UP; which could get very ugly if a car was moving fast.
I'll admit to going quite quickly down there in the past, but be aware there are a lot more cyclist than I've seen before.
Thanks for the feedback fellahs.
Forewarned is forearmed even though I came down there again this morning. I hadn't noticed any 40Km sign below Lennox Bridge yet.
Hate to get pinged doing 72 in a 40 zone gulp.
  • 5 weeks later...
  • 9 months later...
GOD12A, on 03 Sept 2011 - 18:59, said:
I drove to Jenolan Caves yesterday for a caving trip and took the GTR out as I remember the roads being kinda fun. Well damn was I right!!
Jenolan Caves Rd from the Great Western Highway is awesome. Very open, easy to drive at speed with relative safety and the roads aren't that bad at all (I run TEIN Super Streets on 18s)
It's a big boring drive along the highway to get there, but for a nice day trip with the missus, I strongly suggest taking the 'fast car' out for a blat wink.gif
Also, Hawkesbury Rd at Yarramundi. My fave local hillclimb!! I've never had a car stick with me, even when I had the bridgeport RX3, and the GTR is even faster up there. Willing to accept any challengers smile.gif
Mark!!
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
