Nissan S13/S14/S15 Misc parts. Universal parts
* Catch can $10
* Turbo XS loud BOV. $40
* Trust/Greddy copy BOV with pipe $40
* Apexi air filter $30. misc air filter $
* 3 hole Pillar gauge with oil bar gauge $10
* Sony Explode 2x12inch subwoofer in box (1xslight damage). $60.
* JBL 10inch sub woofer. GTO competition series $70
* Rockford forsgate Splits brand new $60
* Blacktop engine pistons $20 for all four.
* Have 2 turbos for Skylines RB25DET or RB30DET VL engines. $150 for both
* JVC double din Mp3 player with remote. $80.
* New black Bucket seats vinyl leather $370 pair no rails.
* 18x7.5 Multispoke inch rims 5x114.4 pcd chromies $280 with 3 ok-good tread. Fits nissans.
* 18x7.5 inch 5 spoke chromies $280. with 4 tyres. some good tread
* 17x9 inch 5x114.3 JDM light weight Rays Engineering / Toms racing C7R. 5 spoke polished rims and tyres $650.
S13 Parts
* S13 fuel rail system with injectors $30
* S13 radiator $60
* Rear window $80
* Front new corner lights $60
* Front projector headlights (broken backing) $50
* Black rear spoiler $10
* Pair of rear lights $50
* Rear quarter windows pair $100
* S13/180sx odometer cluster 185ks $20
* Automatic Gearbox with auto-shifter $200
* Steering Column with switches $50
* Steering rack $50
* Castor rods pair $50
* Front pair stock seats $30 both
* Adaptor wheel hubcentric adaptor plates 20mm fronts and 25mm rears (one plate is missing a stud. Easy fix. you can buy stud for $4. asking $100 the lot
Converts 4x114.3 to 4x100. Makes your wheels sit flush with guards.
S14 parts
* S14/15 SR20DET plenum $20
* S14/15 2x Manifolds $10 each
* S14/15 SR20DET oil sump. $20
* S14/15 SR20DET Boost solonoid $10
* S14/15 SR20DET Alternators $20
* S14/15 ignition coil leads $30 each set of 4
* S14/15 AFM rubber intake hose $10
* S14/15 Afermarket Dump pipe $50
* S14/15 Drift Pineapples new set $40
* S14/15 Clutch assembly $200. Used still has meat 60%
* Stock BOV SR20DET with hose $15
* S14/S13 4x stock intercooler setups with many hoses including S14 front mount piping $50
* S14 Stereo din pocket $10
* S14 Air conditioning cores $30
* S14 heater core $30
* S14 Standard exhaust system $60
* S14 Brake master cylinder $40
* S14 Brake slave cylinder $40
* S14 Starter motors $30
* S14a New passenger Corner light $50
* Boot lids $30 each Purple and in red
* Rare 3 piece Navan rear boot spoiler. Aggressive look $30
* Purple Series 1 bonnet $50.
* Front guards series 1 $100 pair. Purple or white colour
* Front Series 1 front bar $50
* Front headlights and corner lights $100
* Rear tail lights and garnish $60 complete 2 sets
* Standard suspension front and rear $70
* 3.5 inch drop rear springs $30
* stock Front springs $20
* Passenger and Driver complete full doors in green. $200 for both
* Door trimmings Series 1. Have 2 sets. $30 pair
* DR and PSG Mirrors $30 in blue and red. Comes with motors
* Vertex sideskirts $100
* S14a Vertex front bar $150
* S14a Edge bar in red $150
* Vertex Indicator lights for front bar $50. Have 2 sets
* Crossmember to suit S14/s15 $20
* Rear brake calipers assembly $20
* Hard to find. S14a front clear Bonnet protector $50
* Damaged carbon fibre S14a bonnet (can be fixed) $40
* New in box wiper motor
S15 parts
* Black full carpet mould $10
* Side steps off a GT S15 $20
* Front window wiper setup $10
* GT S15 both black front sunvisors $20
* Rear driver side taillight. Slight small chip $20
* S15 ecu japspec $80
* Plastic mirror cabin inserts pair. $15
* S15 fuel pump with top fuel spindle top $60
* S15 Air box with hose to clear RTA defects. $70
Photos upon request.
All parts are negotiable. Make an offer. SMS. or email mailto:[email protected]
Dont have the room space. Need it all gone.
Pickup at Canley Heights/ Liverpool
UPDATED. PARTS SOLD REMOVED.
* Catch can $10
S13 Parts
* S13 radiator $60
* Rear window $80
* Steering rack $50
S14 parts
* S14/15 1x Manifolds $40 each
* S14/15 stock Dump pipe $50
* Stock BOV SR20DET $20
* New in box wiper motor $40
S15 parts
  • 1 month later...
* Catch can $10
S13 Parts
* S13 radiator $60
* Rear window $80
* Steering rack $50
S14 parts
S15 parts
hey mate im interested in your S15 ECU can you pm me your number so i can call you as i want to buy it off you if its still for sale hope to here from you soon thanks kym
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
