Hey fellas,
Had may car in for a tune recently and was told my boost controller wasn't working. (one of the earlier model HKS EVC's).
So obviously I'm looking to get one back in ASAP and was wondering what's the way to go in ways of value/quality without going full on overkill.
In a brief look through the forums I've heard good things about the G-Reddy Profec B Spec II.
Any +1's or opinions on that, or other option would be much appreciated.
Thanks in advance.
https://www.sau.com.au/forums/topic/361961-electronic-boost-controllers/
Thanks guys, I'll have a look at these links, from forum opinion the G-Reddy Profec B Spec II seems to be the way to go haven't heard a bad word against it, so I'll look into getting myself one.
Thanks again.
Is this too good to be true?
G-Reddy Profec B Spec II - eBay
I would normally never consider buying anything for my car off eBay, but i thought I'd check.
Money's not the issue, but if given the chance I'd think we'd all like to keep some of what we earn.
hey mate,
got my spec 2 from performance wise, they are on the forums here. after my payment cleared it took two days to get to me (from japan too). trackable post and awesome price i cannot reccomend them strongly enough!
mick
I just bought a Gizzmo ms-ibc.. supposedly the goods after doing a bit of searching on this forum.
The world's fastest gts-t runs the same controller, so i thought why not :P
Anyways, mine gets installed and tuned on saturday. Car already has a boost controller but a crappy one so basically looking for boost ramp rate improvements not peak power (which i expect to remain unchaged as it will still run the same boost).
Apexi AVC-R anyone? Ive got one and i find it to be pretty damn cool,.. even better when u know how to use everything on it :thumbsup:
Pricey but got some pretty cool features, cant remember all the shit it can do so i copied this off RHD
Description APEXi AVC-R Boost Controller. This can be used on virtually all turbo vehicles.
Here is what Apexi has to say about their product:
The AVC-R is a digital boost controller that allows the user to modify the boost pressure level on turbocharged vehicles. While there are many boost controllers on the market, none of the other includes as many features as the AVC-R, period. Despite all of the complex features included the unit, the AVC-R is flexible enough to be used by beginners. Entry level users need only to input a desired boost level and the AVC-R's trademark self learning CPU processor does the rest.
The AVC-R also uses a highly durable, fast action solenoid valve to physically control the boost . The valve movement (Boost Duty Cycle) can also be modified. Raising the duty cycle increases boost response, while lowering the duty cycle will slow boost response. This feature allows boost response adjustment for varying turbo sizes. Since larger turbos take longer to spool up ( bad low end response) the duty cycle should be raised under lower RPM's for better response. The opposite should be done for smaller turbo's ( excellent low - mid range response, but limited top end power.) A'PEXi engineers address this issue by including extra menus for RPM based boost control. Drag racers may want to utilize the Gear based boost control function. Aside from the basic functions above, the AVC-R has a Start Duty Setting (allows the boost to momentarily overshoot according to gear).
The AVC-R also includes a Scramble Boost function which allows the user to momentarily raise or lower the boost level at the push of a button. Raising the boost level is commonly used when an extra burst of power is needed (ex. entering a freeway). This feature can also be used in drag racing. The driver can set the main boost level to a low setting for maximum traction then, once full traction is achieved, the scramble boost can allow the vehicle to boost full power.
The AVC-R displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. Peak Hold is also included in this function. The Graph Mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds.
Unfortunately the apexi avc-r has no gain setting i don't think...losing precious boost ramp rate.
This is the reason i just purchased the gizzmo.. so i can ditch the PFC boost controller kit.
Several years ago dirt_garage did some testing and found switching from the avc-r to a blitz dual solenoid found gains even when running same boost pressure.
The amount of info it can display is handy though!
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
