Hey fellas,
Had may car in for a tune recently and was told my boost controller wasn't working. (one of the earlier model HKS EVC's).
So obviously I'm looking to get one back in ASAP and was wondering what's the way to go in ways of value/quality without going full on overkill.
In a brief look through the forums I've heard good things about the G-Reddy Profec B Spec II.
Any +1's or opinions on that, or other option would be much appreciated.
Thanks in advance.
https://www.sau.com.au/forums/topic/361961-electronic-boost-controllers/
Thanks guys, I'll have a look at these links, from forum opinion the G-Reddy Profec B Spec II seems to be the way to go haven't heard a bad word against it, so I'll look into getting myself one.
Thanks again.
Is this too good to be true?
G-Reddy Profec B Spec II - eBay
I would normally never consider buying anything for my car off eBay, but i thought I'd check.
Money's not the issue, but if given the chance I'd think we'd all like to keep some of what we earn.
hey mate,
got my spec 2 from performance wise, they are on the forums here. after my payment cleared it took two days to get to me (from japan too). trackable post and awesome price i cannot reccomend them strongly enough!
mick
I just bought a Gizzmo ms-ibc.. supposedly the goods after doing a bit of searching on this forum.
The world's fastest gts-t runs the same controller, so i thought why not :P
Anyways, mine gets installed and tuned on saturday. Car already has a boost controller but a crappy one so basically looking for boost ramp rate improvements not peak power (which i expect to remain unchaged as it will still run the same boost).
Apexi AVC-R anyone? Ive got one and i find it to be pretty damn cool,.. even better when u know how to use everything on it :thumbsup:
Pricey but got some pretty cool features, cant remember all the shit it can do so i copied this off RHD
Description APEXi AVC-R Boost Controller. This can be used on virtually all turbo vehicles.
Here is what Apexi has to say about their product:
The AVC-R is a digital boost controller that allows the user to modify the boost pressure level on turbocharged vehicles. While there are many boost controllers on the market, none of the other includes as many features as the AVC-R, period. Despite all of the complex features included the unit, the AVC-R is flexible enough to be used by beginners. Entry level users need only to input a desired boost level and the AVC-R's trademark self learning CPU processor does the rest.
The AVC-R also uses a highly durable, fast action solenoid valve to physically control the boost . The valve movement (Boost Duty Cycle) can also be modified. Raising the duty cycle increases boost response, while lowering the duty cycle will slow boost response. This feature allows boost response adjustment for varying turbo sizes. Since larger turbos take longer to spool up ( bad low end response) the duty cycle should be raised under lower RPM's for better response. The opposite should be done for smaller turbo's ( excellent low - mid range response, but limited top end power.) A'PEXi engineers address this issue by including extra menus for RPM based boost control. Drag racers may want to utilize the Gear based boost control function. Aside from the basic functions above, the AVC-R has a Start Duty Setting (allows the boost to momentarily overshoot according to gear).
The AVC-R also includes a Scramble Boost function which allows the user to momentarily raise or lower the boost level at the push of a button. Raising the boost level is commonly used when an extra burst of power is needed (ex. entering a freeway). This feature can also be used in drag racing. The driver can set the main boost level to a low setting for maximum traction then, once full traction is achieved, the scramble boost can allow the vehicle to boost full power.
The AVC-R displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. Peak Hold is also included in this function. The Graph Mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds.
Unfortunately the apexi avc-r has no gain setting i don't think...losing precious boost ramp rate.
This is the reason i just purchased the gizzmo.. so i can ditch the PFC boost controller kit.
Several years ago dirt_garage did some testing and found switching from the avc-r to a blitz dual solenoid found gains even when running same boost pressure.
The amount of info it can display is handy though!
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
