  • Replies 61
  On 25/04/2011 at 5:08 AM, Count Grantleyish said:
Best street combination for stock motor IMHO, much better than -7s.
Bollocks :nyaanyaa: A *little* better than -7s when you're over 300kws otherwise SFA difference.
I'm 305kw @17psi with -7s.
OP;
- turbos are key part of the equation, no sense in getting -5s just because they're cheaper. You get them if you want 380kws. For 300 they're a bad choice.
- if you're ever going to do dumps, do them now, but you could just as well not bother. If you look at cost/benefit, -7s without dumps will be much better than -5s with dumps for around the same cost.
- when i checked pricing, -7s were $400 cheaper for the pair than -9s with new actuators. Dont use old actuators....
- you're thinking about cams (waste) but maybe buying -5s to save a little money? That doesn't make sense. You need to let us know how tight the money is and what results you want.
Option 1 - 280kw - cheap; -7s, cam gears, stock dumps, injectors, AFMs
Option 2 - 330kw - medium; -9s, cam gears, 550 injectors, nismo AFMs
Option 3 - 380kw - exxy; -5s, cam gears, 700 injectors, nismo AFMs, dumps, oh and BUILT MOTOR and gearbox upgrade to keep 3rd gear in one piece....
And Nismoid's exhaust rule;
300kw = 3 in
350kw = 3.5 in
400kw = 4 in
  On 25/04/2011 at 5:18 AM, Piggaz said:
Grant. As good of a result that people have good power with stock dumps...there would have to be more to be made with a larger... Ie tomei, midori dump pipe.
True, but kinda pointless if you only want 300rwkw or so, which I've done with success before.
But next time I may go for a pair of a/m dumps and see if it make any difference.
To much MrStabby thats uesfull stuff
Lets say your running 300kw on -9s and the engine goes after a year,then a rebuild is taken place, forged bottom end.and you wanna run 400kw that means you gotta buy -5s and sell of your -9 in away your loseing money ?so is it better of to get -5s striaght away?
its basically the same thing
the nismo is z32 hotwire inside 65mm shell
the z32 is 80mm z32 airflow meter
so more or less the same
but in a twin setup the twin nismos will give you more resolution in low load area as the snout is smaller
I'd buy -9s and enjoy while it's there.
Buy -5s when the motor is out, people still will buy -9s even if used.
Pretty sure Ash will say the same.
Hey R33GTRNZ i think we;re on the same boat im from NZ to,im after a pair of -9s,was looking at some 2nd hand N1 turbos might be the cheaper option,i do wanna run 400kw but not with the stock motor and also dont wanna rebuild a perfect running engine :rant:
Edited by nitestage32
Depends on what you want and stuff mate.
Nothing wrong with running -9s on a built motor. It'll make a solid 330rwkw, be responsive as all buggery and be an absolute street weapon. So if thats all you want then you'll not need to change turbos!
I've got 370rwkw now with -5s... I'd rather the response of -9s and 330-340rwkw. Admittedly I'm running less boost on the -5s than i could but response is king for a street car and makes it so much nicer to drive.
I don't dislike my -5 setup. However nothing really happens until 150km/h where the -9s were much more exciting between 60-150km/h
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
