  • Replies 61
Best street combination for stock motor IMHO, much better than -7s.
Bollocks :nyaanyaa: A *little* better than -7s when you're over 300kws otherwise SFA difference.
I'm 305kw @17psi with -7s.
OP;
- turbos are key part of the equation, no sense in getting -5s just because they're cheaper. You get them if you want 380kws. For 300 they're a bad choice.
- if you're ever going to do dumps, do them now, but you could just as well not bother. If you look at cost/benefit, -7s without dumps will be much better than -5s with dumps for around the same cost.
- when i checked pricing, -7s were $400 cheaper for the pair than -9s with new actuators. Dont use old actuators....
- you're thinking about cams (waste) but maybe buying -5s to save a little money? That doesn't make sense. You need to let us know how tight the money is and what results you want.
Option 1 - 280kw - cheap; -7s, cam gears, stock dumps, injectors, AFMs
Option 2 - 330kw - medium; -9s, cam gears, 550 injectors, nismo AFMs
Option 3 - 380kw - exxy; -5s, cam gears, 700 injectors, nismo AFMs, dumps, oh and BUILT MOTOR and gearbox upgrade to keep 3rd gear in one piece....
And Nismoid's exhaust rule;
300kw = 3 in
350kw = 3.5 in
400kw = 4 in
Grant. As good of a result that people have good power with stock dumps...there would have to be more to be made with a larger... Ie tomei, midori dump pipe.
True, but kinda pointless if you only want 300rwkw or so, which I've done with success before.
But next time I may go for a pair of a/m dumps and see if it make any difference.
To much MrStabby thats uesfull stuff
Lets say your running 300kw on -9s and the engine goes after a year,then a rebuild is taken place, forged bottom end.and you wanna run 400kw that means you gotta buy -5s and sell of your -9 in away your loseing money ?so is it better of to get -5s striaght away?
its basically the same thing
the nismo is z32 hotwire inside 65mm shell
the z32 is 80mm z32 airflow meter
so more or less the same
but in a twin setup the twin nismos will give you more resolution in low load area as the snout is smaller
I'd buy -9s and enjoy while it's there.
Buy -5s when the motor is out, people still will buy -9s even if used.
Pretty sure Ash will say the same.
Hey R33GTRNZ i think we;re on the same boat im from NZ to,im after a pair of -9s,was looking at some 2nd hand N1 turbos might be the cheaper option,i do wanna run 400kw but not with the stock motor and also dont wanna rebuild a perfect running engine :rant:
Edited by nitestage32
Depends on what you want and stuff mate.
Nothing wrong with running -9s on a built motor. It'll make a solid 330rwkw, be responsive as all buggery and be an absolute street weapon. So if thats all you want then you'll not need to change turbos!
I've got 370rwkw now with -5s... I'd rather the response of -9s and 330-340rwkw. Admittedly I'm running less boost on the -5s than i could but response is king for a street car and makes it so much nicer to drive.
I don't dislike my -5 setup. However nothing really happens until 150km/h where the -9s were much more exciting between 60-150km/h
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
