hear we go, the head gasket in my car is less than 6 months old. and it started leaking coolant at rear of the motor by the firewall. so after further inspection i found out it's the damn head gasket. the retard that last replaced it did not put the outer 3 water jacket bolts in. so i put some bolts in it and it just slowed the leak down but it is still leaking. The car does not smoke or have oil in the coolant so I'm guessing that only the outer part of the head gasket is messed up. so im getting ready to replace the head gasket and have a couple of questions.
1.) i have looked and i cant find a good write up on replacing the head gasket. i have never replaced a head gasket on a non American car. anyone seen one? be nice to have a link.
2.) there is good ARP head bolts in it now, can i reuse them or are they trash after being torqued once?
3.) what about a good place to buy a head gasket set? i will probably just stay OEM as the most boost the car will see is around 1.3 bar.
motor came out of a 99 Stagea and is in a r32 GTS-4. any tips, tricks or advice before i start would be appreciated.
https://www.sau.com.au/forums/topic/361971-replacing-rb25neo-head-gasket/
find a copy of the RB engine manual, there are a few floating around the interpascals.
A Head Gasket is a head gasket, only pain in the arse part about the RB is getting the cam timing spot on after its all back together.
I doubt its leaking because of those 3 small auxiliary bolts on the side as when I bought mine it had none of them on and there was no leak, more likely its been incorrectly installed or torqued especially if there ARP studs you got to do it right or else they will lose tension.
As for changing it just take it slow and yes it is like any other car just check the head and block to see if it is within range for straightness and also make sure you clean the surface very well not leaving any of the old gasket on. If you dont cut any corners and do everything properly there should be no reason to have a leak again.
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
