hey guys i dont use my modified stagea much these days and looking to purchase a house so im thinking of selling it but unsure what it is worth and if anyone would be interested in such a setup, or maybe its better to strip it back to stock and sell all the parts off?
im not too fussed if i sell or not, i have had the car since 2004 (and been on theses stagea forums since then), it has undergone alot of changes in that time, and recently featured in Performance Imports magazine with the old setup it had. It is no where near as modified as it was in the magazine as i got a defect notice and decided to make it completely legal and put the modified engine into a track only gtr instead.
The mod list is pretty long but here is the basics to give you an idea...
rb30 bottom end, freshly rebuilt with new pistons (not forged but stronger than stock, they are called Endurotec and made by Precision), its got a crank collar on the crank, all assembly was washed, machined and balanced. Has done about 2000km so far. It has a gtr oil pump on it, brand new water pump, new tensioner and idler pulleys, new timing belt and all new seals, and hks drag metal head gasket 1.2mm.
rb26 head is also recond and in as new condition with all standard rb26 gear.
The block also has a "Pro Engines" 4wd sump adaptor kit fitted to allow for the gtr 4wd sump to be used.
this is a copy and pasted list of the mods i can remember...
stagea rs four s1 silver
mods:
rb30 rebuilt bottom end
king bearings
endurotec 86.5mm pistons
hastings rings
Proengines 4wd sump adaptor
gtr 4wd sump setup
rb26 head & plenum setup
freshened up with new valve stem seals, redone valves, shims setup, deck etc
hks drag 1.2mm metal head gasket
hks drag metal intake and exhuast gaskets
gt3076r turbo
custom steam pipe manifold
hks 50mm wastegate
3' dump pipe and exhuast with magnaflow muffler and an apexi centre muffler
K&N pod filter
custom alloy cooler piping and intake pipe
custom metal oil and water lines
gtr 5 speed manual box
extreme single plate clutch
32 gtr diff and axles
33 gtr brembo rear brakes
34 gtr brembo front brakes
dba 5000 alloy hat front slotted rotors
dba 4000 rear slotted rotors
custom adr approved braided brake lines
r33 handbrake
4.11 front and rear diff ratios
autronic smc ecu
eboost 2
defi 3 din gauge setup
whiteline springs all round
bilstein shocks all round
all noluthane bushes throughout front and rear
arc front swaybar
whiteline rear swaybar
adjustable camber bushes
nismo lmgt2 rims 18x10
dayz rear bumper lip
nismo copy sideskirts
thats about it i think lol.
i have invested alot of money into the car over the years and only used top quality parts throughout.
heres a couple of pics of the motor and car itself
i have full engineer reports for all mods and engine conversion/brakes/etc, the only mod not approved is the single turbo, i can put stock rb26 twins back on it and take abit of money off the price and then its fully legal. The engine block is stamped as an rb26 so no worries as no one can tell its a rb30 at all, passed the inspections with no dramas.
this is a pic with stock turbos on it and looks completely standard to the untrained eye. You can put some upgraded low mounts on it and make heaps of power without any issues with police etc.
The current setup is only roadtuned but making around 350hp at wheels, and cam timing hasnt been touched yet so has alot more in it, and should make low 400s without any dramas or reliability issues at all.
so what would you guys think it is worth?
As sad as it is, the money you have put in. Is going to be many times what younwd get for it, it looks maybe too far to go back to stock, As finding an engine etc wd out weigh wat an s1 is worth. Let alone the scare factor when you tell people its not factory engine etc. The motor alone wd fetch ~10k dont we think? Other than that ur breaks, handelind mods n gbox wd get u a bit more. Strip it n move on..?
yeah likewise, i would have bought it pretty dam fast a few months ago, but if you strip it, let me know how much the brakes are, hawttttt
btw, dont strip it or sell it, just hold onto it and use it when you can
What's it worth? A lot more than you could ever sell it for.
Plan A - just keep it (what are you towing your track car with?)!
Plan B - stick a price on it that you would be happy with and wait for someone to come on this forum looking for a good C34 and buy it.
Plan C - if you must sell it wait until you can organise an engine swap with someone - I would have paid someone $10k and given them my old engine for one like yours - (and as many other bits as they can afford) and then sell it.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
