Bruno P Posted April 24, 2011 Share Posted April 24, 2011 (edited) Hi I just purchased Clutch Kit, Exedy Extra Extra Heavy Duty Button for an RB25det, Manufacture Part No: Exedy NSK-7056HHHDB with the following specs Diameter: 240.00mm Spline OD: 25.50mm No of Teeth: 24 Pressure Plate Type: Push Pressure Plate Clamp Rating: 14,680N / 1,497kgf / 3,300lbf *Power Holding Capability (At Flywheel): 700hp / 523kw Reason for purchase is my current button clutch slips badly in 3rd gear when car is under load, so I thought I would upgrade to something better. I have also ordered a Nismo clutch pivot as I heard the standard one can sometimes break So my first question is do you think its ok to machine the current standard nissan flywheel or do you think its necessary to purchase an aftermarket one? I was thinking of purchasing this Flywheel (Lightweight), EXEDY racing flywheels are made from solid one-piece forged chrome moly steel. They are specifically designed to reduce weight and inertia for improved engine response. Manufacture Part No: Exedy NF01 Please advise. Also im wanting to purchase a Seal Kit (Gearbox), Genuine Nissan Skyline R33 GTS25-t (RB25DET) for my r33 gtst because i seem to have a bit of oil surrounding the gear box This kit contains the following genuine Nissan components: Engine Crankshaft Rear Main Seal Gearbox Front Cover Gasket Gearbox Front Main Seal Gearbox Tail Shaft Seal Crank Spigot Bush So my second question is, Is it possible to install the above components whilst Im installing my new clutch.? Any comment welcome Also could a rear main seal cause my clutch to slip this badly? Cheers Edited April 24, 2011 by Bruno P Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/ Share on other sites More sharing options...
33driver Posted April 25, 2011 Share Posted April 25, 2011 its not necessary to purchase a new fly wheel, machining the old one is fine. That said, I have the exedy lightweight in my car and it makes a big difference. Most of those seals can go in while you are doing the clutch, but you'll need to split the gearbox I think (someone else may know more than I) to put some of those seals in which is not a small/quick job. Rear main would only make your clutch slip if its leaking and getting oil on the clutch itself, which will be easy to tell once you drop the clutch. Good practice to replace that seal anyway while your in there IMO though anyway. Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/#findComment-5777970 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted April 26, 2011 Share Posted April 26, 2011 i run that clutch with a stock flywheel that was machined fwiw Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/#findComment-5779431 Share on other sites More sharing options...
Bruno P Posted April 30, 2011 Author Share Posted April 30, 2011 thanks for reply. Ive done the crazy thing and ordered a lightweight flywheel, I read somewhere that it wont necessarily give you extra hp/kw on the dyno graph, but it lets the engine rev up very quickly and allows the engine to work easier due to the reduced weight spinning around on the back of the crank...hope it works well wih extra heavy duty button clutch. as for the seals yeah i wont purchase them until im absolutely sure they are needed. its not necessary to purchase a new fly wheel, machining the old one is fine. That said, I have the exedy lightweight in my car and it makes a big difference. Most of those seals can go in while you are doing the clutch, but you'll need to split the gearbox I think (someone else may know more than I) to put some of those seals in which is not a small/quick job. Rear main would only make your clutch slip if its leaking and getting oil on the clutch itself, which will be easy to tell once you drop the clutch. Good practice to replace that seal anyway while your in there IMO though anyway. Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/#findComment-5786823 Share on other sites More sharing options...
Bruno P Posted April 30, 2011 Author Share Posted April 30, 2011 hi just out of curiosity is the exedy hhhdb clamp load too heavy on the leg? as apposed to the standard skyline pressure plate? Cheers i run that clutch with a stock flywheel that was machined fwiw Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/#findComment-5786830 Share on other sites More sharing options...
Shazza24 Posted April 30, 2011 Share Posted April 30, 2011 Is it a daily driver? It is safe to say that it will be heavier than standard clutch. (I run a HD clutch and it was a bit of getting used too but not bad) BTW, you should do your seals at the same time as the box will already be out. The rear main seal is a common-ish one to leak. Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/#findComment-5786881 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted April 30, 2011 Share Posted April 30, 2011 yeah, it's well heavier, but you get used to it Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/#findComment-5787763 Share on other sites More sharing options...
Bruno P Posted May 4, 2011 Author Share Posted May 4, 2011 nice waiting on delivery and will get started yeah, it's well heavier, but you get used to it Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/#findComment-5794822 Share on other sites More sharing options...
boostn0199 Posted June 10, 2011 Share Posted June 10, 2011 Whats the part number for this clutch because it is not on there website? Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/#findComment-5860086 Share on other sites More sharing options...
boostn0199 Posted June 10, 2011 Share Posted June 10, 2011 My mistake missed it in the first post. Link to comment https://www.sau.com.au/forums/topic/361999-advise-clutch-kit-exedy-extra-extra-heavy-duty-button/#findComment-5860089 Share on other sites More sharing options...
