JDM R35 2 1/2 years old
Tried to start it about 3 weeks ago, the battery was a bit low as I hadn't used the car for 2 months.
First it wouldn't start. all dash light on,
starter button nothing, but the headlights came on, and the headlight switch could not turn them off.
Then it finally started,but It wold stop.
Tried disconecting the battery, car still running, headlight still on, no way to stop it,apart from clamping a fuel line.
Tok it for a drive, after about 6 kms the headlights went off.
drove for 12 kms, stopped, and the starter switch stopped the car and it started again normally.
Everything operating as new again.
Tried to start it again yesterday, dash lights on, headlights on again, starter switch nothing.
Disconected the battery, dash light and headlight off.
So I charged the battery over night and tried again this morning, same thing again , dash and headlight on but it won't start.
Had to disconected the battery to turn the lights off.
Help Help any ideas all please???????
https://www.sau.com.au/forums/topic/362025-help-r35-gone-crazy-again/
Thanks guys but it's not the battery.
Battery shows 12.9 volts plus tried a jump starter as well.
why are the headlight coming on?
Why wonldn't the engine turn off when it was running?
It must be to do with the can bus system somewhere.
might need a consult 3 to check it out.
Batteries can show 14V and still be stuffed, especially after sitting around unused then quickly charged
I agree but I have a multi meter on it and when I press the start button the voltage doesen't change, just silence.
OK the puzzle contunies
reconnect battery but first check current draw as it sparks a little as I connect and disconnect.
doors open interior light (door0 on close door? no windows up
reconect battry lower windows a bit close doors, check current draw .4 amps.
reconnect battery check for fault codes with cob
Troubleshoot reports "no codes"
ignition is on so I press the start button
this it goes off
Soooo try again and foot on brake MAGIC it start and press button again it stops
ALL fixed working perfectly again.
TILL NEXT TIME
this car is a worry
Thanks again Martin for trying
Jeff
Its not over yet.....(the trying)
Take the battery out of the car (disconnect it) for 5 minutes and reboot the CAN bus.
I have had it disconnected all night as I had it on charge.
still had the same "no start" problem.
and why do the headlight come on and won't turn off
It's all a mystery
You should Water Spray those brakes..... :)
Two things I would do -
Replace battery just for the fun of it - stop any stray noise potentially on the CAN bus.
Secondly drop the Steering Lock and lubricate the firing pin
I know none of this makes any sense - but give it a go :)
they sound like long shots to me
but I repect your experience with these cars
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
