So i got defected for this item last night, owned the car for 4.5 years and never had a problem. It's a dual port turbosmart BOV, So the trumpet is on one side and the other is plumb back...i read up on this and apparently they come with a blanking plate. The BOV was on the car when i bought it so i didn't receive this item (Blanking Plate).
I was under the impression that it could just be changed back without having to take the trumpet off, cuz the cop last night had to watch it go off. But if it is suppose to be removed and a plate put over the top, wouldn't you just defect all bov's with a trumpet?
Anyways i don't mind having to stop it...Is there anything particular i need to watch for if i cap this off, or would it actually be considered better, performance wise?
Where is the best place to find these covers?
Cheers
https://www.sau.com.au/forums/topic/362032-turbosmart-bov/
So is it currently using the recirc or not?
If you block off the ATMO side, you'll need to ensure the recirc side is all connected. Then no problem.
You could probably order the plate off a turbosmart distributor/stockist. If not just have one made/cut up. Wouldn't be expensive.
https://www.sau.com.au/forums/topic/362032-turbosmart-bov/#findComment-5777899
Go here, http://www.turbosmar...index.php?id=47
The part you will need is a 'BOV Port Blanking Plug'
Model number: TS-0205-3103
It's better plumbed back if you run a stock ECU. Buy the plug, unscrew the trumpet, screw the plug on. Done.
Autobarn have these plugs.
Edited by Aleckr33
https://www.sau.com.au/forums/topic/362032-turbosmart-bov/#findComment-5779999
cheers...just did a google image search...
are these plugs round? i was thinking that'd just be like a rectangle plate that replace the trumpet plate.
Or is it round and goes in the hole and put the trumpet back on top of it?
https://www.sau.com.au/forums/topic/362032-turbosmart-bov/#findComment-5780022
mine looks a little different, the trumpet is on a rectangle plate. Same with the plumb back side, its got 4 allen keys holding each in place.
http://i11.photobucket.com/albums/a153/spiralsmurf/DSC01184.jpg
Edited by 3340TH
https://www.sau.com.au/forums/topic/362032-turbosmart-bov/#findComment-5780239
y's that? the part on the right goes back into the intake. 50% goes that way 50% goes out the trumpet. Would it damage something to put 100% back through the intake side?
Edited by 3340TH
https://www.sau.com.au/forums/topic/362032-turbosmart-bov/#findComment-5780274
I bought the car in 06 and was on it then..i just pulled it out then, trying to find an allen key that will fit it right...but it looks as though i can remove the whole plate, but also the trumpet goes inside the plate...so whether i can unscrew it from that plate is another story but i cant budge it atm.
EDIT: It unscrews.
Also whats the business with the hard soft with the tension of the spring. better hard or soft?
Edited by 3340TH
https://www.sau.com.au/forums/topic/362032-turbosmart-bov/#findComment-5780357
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
