Fresh RB25 for sale built to same spec as NYTSKY's 430rwkw engine by Red R Racing
Acid dipped, crack tested, bored and strainer plate honed block
crack tested, cross drilled and grub screwed crankshaft
resized, honed and cryo treated RB26 conrods with ARP bolts fitted
CP 86.5mm forged piston kit with custom Red R ring package
ACL race series engine bearings
Nissan N1 oil pump and water pump
Gates timing belt kit with pulleys
cometic 1.2mm head gasket
fully reco'd cylinder head
HKS 256/264 camshafts
OS giken exhaust cam gear
HKS 850cc injectors
Twin scroll stainless manifold
50mm external gate
plazmaman inlet manifold
80mm throttle body
engine is only missing a turbo as im using the t04z twin scroll on my 30/26 engine.
it comes with an option of a Red R 8.5 litre sump fitted
this combo is a proven performer built by one of the best RB builders in aust.
$8900 or $9500 with race sump
https://www.sau.com.au/forums/topic/362039-nytsky-spec-built-rb25/
Supa Steve,
Can you ask your mate, Paul, to either call me and/or send me my oil pump please. He seems to be uncontactable.
you may need to leave a message if you cant get hold of him NX. Ive got to call them tommorrow to arrange an inspection of the engine for a buyer so ill let Paul know.
PM's replied to.
to those pm'ing about warranty, Paul stands by his work and is prepared to provide start-up warranty as well as advice on run-in procedure etc.
his after sales service is excellent and looks after customers long after engine is installed running and tuned.
PM's replied to.
Mate,
Paul is well aware of the situation (and I have spoken/sms'd/left messages to him many, many times about it) and I am sure he knows what must be done. Perhaps you could quietly remind him again when you see/speak to him next.
Thank you.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
    • After its dried out Penetrol is you friend to treat rust and seal up those seams
