  • Replies 295
SNES is still my favouite console of all time. n64 graphics were fail. gameplay went down the tube because they were too busy making 3d platformers. i didn't mind golden eye, and mario kart 64 was the best of the mario kart games, but overall, i still prefered the SNES. now that snes games, such as donkey kong and mario are making a come back in 2d side scrollers on the WII i'm happy, but the fact that some of them can't be played with a regular controller shits me to tears. fkn hate having to shake the controller to get it to do certain moves because half the time it doesn't work. for this reason i haven't played much of the latest donkey kong game.
ahhh i remember the late nights on perfect dark in the complex. with the slayer on the 3rd level ( weapon drop #5) hunting the bastards down with fly-by-wire rockets. while a laptop gun kept me safe form atack.
and lets not forget the good ol VengeSim's..... little bastards :laugh:
Playstation Store to return online May 24th - Report
Each PSN user will be able to get two PS3 titles and two PSP titles at no charge from a limited list of first-party games. In North America, the PS3 list consists of Dead Nation, Infamous, Little Big Planet, Super Stardust HD, Wipeout HD + Fury. The PSP selection is Little Big Planet (PSP), ModNation Racers, Pursuit Force, and Killzone Liberation.
So back to a previous question I had. Would this mean each user gets two games or only each PS3?
And btw, MGS had the best storyline EVER!
Though the best game I've played is Donkey Kong Country 2: Diddy's Kong Quest. It was perfectly balanced (i.e. hidden aspects, level difficulty, rage quits) Getting to 102% was a pain in the arse; it also didn't help when your younger brother kept deleting the f**king files.
EDIT - After this story was published, US Sony reps offered the following statement: "We've not announced a specific date other than to say we expect to have the service fully restored by end of the month. Anything other than that is purely speculative."
I guess the free stuff isn't too bad
and yes MGS is the best :cheers:
You really need to go back and play the original Mario Kart.
I did on Saturday (60hz SNES + Game Doctor FTW!) and couldn't believe how much better it was than all the sequels... plus seeing my brother have acute controller rage was tear-shedding hilarious :)
Just on Mario Kart, why did they get rid of the coins and the feather? Two elements that really add to the gameplay... and super-intense short races are infinitely better than the long races of today's Kart tracks.
i own all the mario kart games and do play them on a semi regular basis, but MK 64 is the one that gets the most game time (about 99% of the time i spend playing MK games). it has a good balance of weapons, obsticles and the ability to powerslide is good too. also the fact that the tracks aren't flat ads a bit to the gameplay as you have to thing a little bit more, picking best lines up hills and over jumps, etc.
Yeah from memory the graphics on the N64 were way better than the PS1.
Technically the N64 had the better graphics hardware compared to PSX, however the games on the N64 have very limited storage space due to the use of the old cartridge media, most of the games had to be limited in that regard.
I love my China bought PSX with its built in mod-chip :closedeyes:
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
