Hi Guys,
Please forgive me if i have done this wrong, never posted before.
I have reciently bought a 33 with a nismo lcd dash (not connected to anything) and was wondering if someone can help me out. At the back there is a RCA plug and 2 pins under it, im guessing there for power. Does anyone know which is positive & negitive?
any help would be greatly apreciated!
https://www.sau.com.au/forums/topic/362118-r33-nismo-lcd-screen-wiring-help/
yeah there is the ej1 and other systems,
I have a deck that plays dvd's and i was going to plug that in through the rca lead to test if the lcd screen works but i think the two pins below are for power and was just wondering if anyone knew which was neg and pos?
just to confirm for you, yes those pins are the power to the screen.
I have one of these in my car hooked up to the ej1 unit. But unfortunately off the top of my head I do not recall which of the pins is positive and negative, as mine was all ready to go with a power cable still fitted over them :P
Edited by Skysthelimit
  • 4 weeks later...
Hi i bought one of these nismo lcd cluster, but it only came with the navigation system..does the navigation work in australia and have english? also i have a motec ecu..if i cant find a epson ej1 system am i best off with the HKS CAMP or HKS CAMP2 ? please help if can
thanks
thanks
i had an EJ1 its broken the display chip is faulty and the display is scrambled.
Best bet is to get the HKS Camp 2 and the Nissan Consult harness it works really well and has allot more features compared to the EJ1.
You can also buy optional sensors for the HKS Camp 2 like boost, oil pressure, exhaust temp, oil temp etc
hey ok cool thanks for the help..ill look into the camp2
hey ive been reading throu some other post about the hks camp2..will it connect to a aftermarket ecu ?
There is a possability the HKS Camp 2 might work with an aftermarket ecu because HKS offer a CAMP 2 Universal Adaptor which has to be hard wired or soldered onto the ecu wires.
Apparently the Universal Adaptor can pick up the following...
SPEED, RPM, INJECTOR, and THROTTLE
Check out the HKS CAMP 2 FAQ's
http://www.hksusa.com/faq/?ID=3516
ok thanks again for the help will look into it more thanks
  • 3 years later...
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
