I would have thought that a brake specialist workshop accustomed to working on ABS actuators would not only have a bunch of suitable O-rings on hand to suit any and all makes but not require their customers to source them beforehand.
Hint...I'm suggesting taking it to a brake specialist - a proper one, not one of those bloody chain store type ones you have in the US - to get it serviced. Given that you're going to take it to "a shop" for the work anyway.
Thank you for the input GTSBoy.
I struggled to find a specialist shop that would do this rebuild (including industrial hydraulic shops and a power steering specialist) even though I live in a fairly large town. So I talked to the owner of a reputable performance shop and he is willing to take on this challenge. I hope improve our chances of this unpredictable rebuild by getting the right sizes of O-rings.
isnt a z32 abs unit similar to the bnr32?
Thank you for the tip Omnigear.
I scan through eBay and find Z32 units looks almost identical to the R32 units. The electrical plugs look different, but that should be easily solved. They are about $50 USD a piece on eBay, so I think I will take a gamble on that.
So why wasn't a Z32 unit mentioned earlier in this post?
Turns out Z32s have two different ABS units, one for 2+2 and the other for 2 seater. I bought an used unit for 2+2 since GTR is also 2+2. I will post updates when I receive it, whether it works or not. I really hope it works because they are fairly cheap and plentiful. Even if the unit doesn't fit I can still take it apart and scavenge O-rings inside.
reman from rockauto.com for a z32 is around 900$ USD here >_< raysbestos have some left overstock i guess.
Mine is still not leaking since the rebuild. Someone who understands orings "SHOULD" be able to figure out what is needed but most people aren't.
I contemplated doing a guide but there is potential for things to go wrong. If or when it goes wrong, you will have no brakes. The biggest chance of something going wrong is from not bleeding it properly.
I would put my effort into fitting a late model Bosch unit in. It can easily be done to look like factory and bleeding would be a breeze. You will need new lines made up and to modify the R32 ABS bracket to accept the Bosch ABS unit.
which bosch and what is required?
Just received Z32 ABS actuator. The exterior dimension is exactly the same, so are the 3 bracket mounting points. The only major difference is the vertical metal pieces used on R32's unit to mount inlet pipes straight up, which can either be reused or just bend the pipes. The plastic housing for relays are mounted directly on top of the motor on Z32's but offset on R32's, which can easily be relocated by reusing the bracket from R32's. The different plugs are not an issue to me.
After a closer examination, each of the 3 cylinders has a different 5 digit part number, and Z32's are different from R32's. I see a total of 6 sets of different 5 digit part number on those cylinders, but at this point I really don't care to speculate about what those part numbers represent.
Z32 ABS actuator is now in! The plugs were swapped over so there was no cutting or soldering of wires. Tested the system 5 times by braking as hard as possible from 50 mph, then drove 35 miles home. So far so good! I took some pictures and will post the details later if this Z32 unit continues to hold. I don't want to give you guys false hope. But heck, I paid $35 including shipping for this used unit, so if you guys can find one just as cheap feel free to experiment with it as well.
  • Like 2
did the abs kick in? how did you do the swap?
Yes the ABS kicked in beautifully! I took my car to a shop specializes in Z32s called Houston Z Auto. I stood next to the owner, Dane Miller, through out the whole process and took some pictures, which I will post later with written details. I can say most of us can do this at home given the right basic tools, a flare nut wrench for the brake lines and a long thin straight metal pick for de-pinning the pins out of a plug. Just remember, although the coloring of wires are different, pin numbering are the same, so upper left matches upper left and lower right matches lower right and so on.
Super big thanks to Dane Miller at Houston Z Auto for meticulously and patiently fitting Z32's ABS unit into my R32. Also big thanks to Omnigear for his keen observation on the similarity of Z32's ABS unit. Now, I can't guarantee that everyone will get the same result, nor can I guarantee my resolution will be permanent, but it sure beats filling the entire brake fluid reservoir once a month.
I bought an used Z32 ABS unit for the 2+2 trim, OEM# 47600-32P00. The unit appears to be in great condition given the low cost of $35 shipped. The unit for a Z32 2-seater, OEM# 47600-30P01, looks to have the same exterior dimension and I believe it will fit as well, but I picked the 2+2 because R32 also has 2+2 chassis. Z32's units will most likely be in much better condition because they are either mounted in the trunk or behind the seat, as opposed to R32's being mounted in the engine bay.
After the R32's unit is removed, here is how it compares to a Z32 unit. Z32 unit has white plugs with relay housing mounted directly on top of motor with no adapter for the brake inlet lines.
And this shows how bad the leak was. The paint is pretty much ruined.
After the 2 relays are removed, the plastic housing can be seen secured to the metal bracket below with 3 screws. After removing housing the metal bracket can be removed, which is an offset bracket and will be used on the Z32 unit. During this step Dane realizes there is a chance that he can swap over R32's oval plugs without cutting and soldering. So a change of plan.
Here is a tip. Jam the thin metal pick into the back side of a plug and its metal bracket, and the plug will come off smoothly. And for reference, here are the pin-outs of the ABS units for R32 and Z32.
So, the 6-pin and 2-pin plugs are attached to the plastic housing and can be transferred to Z32 all together. The 4-pin plug however has the 12v source attached to housing while the other 3 attached directly onto the ABS unit. Using the thin metal pick, the 12v wire at lower right of the plug can be de-pinned. Dane de-pins the 12v wire off Z32's plug and finds both units use the exact same pins. So even though the plugs have completely different outside shapes, internal dimensions are exactly the same, down to the tabs holding the pins.
So now Dane has the confidence to de-pin remaining 3 pins, and soon all 3 oval plugs are off R32 and onto Z32's ABS unit. Next step is to take off the 2 metal adapters for inlet brake lines. Once they are off an obvious issue arises. R32's unit has 2 alignment holes, but Z32's is completely smooth. Now at this point there are a few options, grind the alignment dots off adapters, drill new holes on Z32, or the lazy man's option; just flip over the adapters. Well, I have never been the overachieving type!
Here we are, plugs swapped, housing mounted on the offset bracket, and adapters bolted. Looks just like a R32 ABS unit!
To finish the job off, nice Motul 5.1 goes in for the brake bleeding. That Z32 unit must have been sitting for years, because the crap that came out of it is just unreal. The "Crystal" logo on that plastic cup is especially ironic and funny.
I will report back once in a while to let yall know if this Z32 unit continues to hold. After all it is off a 1992 and only 2 year younger than my 1990.
  • Like 2
This needs to go to the How to section ^_^
So, the 6-pin and 2-pin plugs are attached to the plastic housing and can be transferred to Z32 all together. The 4-pin plug however has the 12v source attached to housing while the other 3 attached directly onto the ABS unit. Using the thin metal pick, the 12v wire at lower right of the plug can be de-pinned. Dane de-pins the 12v wire off Z32's plug and finds both units use the exact same pins. So even though the plugs have completely ifferent outside shapes, internal dimensions are exactly the same, down to the tabs holding the pins.
I may have to drive to houston lol. Mine does the same thing. Although I don't think its terrible yet. But it does definitely leak.
May not be necessary if you have the proper tools. But having the car on a lift surely made bleeding brakes much quicker than at home. The shop also has plenty of Z32s around, so maybe they can find you a donor unit in house. Or if you just want to check them out, it is a very cool shop with their own dyno machine.
  • 1 month later...
  • 1 year later...
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
