I have told my insurance company everything that isnt stock, that way they have no way of trying to stop paying me in the event of a claim..
Why bother telling em only half or so of the things if they are gonna class it as void anyway...
best to declare everything generally... firstly to make sure its covered when an incident occurs and secondly and more importantly to make sure they cant use it as an escuse to not pay up. Most insurance companies will want to know everything, some may not need to know. But i guess thats where a phone call to your particular insurance company will answer that question. Depending on who your with though.. once you get to a certain level of mods they may not want to insure you anymore... or at least not for a reasonable price any longer, this is where somewhere like just car is helpful.
Do I have to tell the insurance company that I have made these modifications?
That depends on whether you want to be covered in case of an accident.
As per the policy the insurer may void your claim if you have unlisted mods. Especially those that could cause you to have a higher risk of accident, either because of mechanical failure or making the car more powerful (and theoretically harder to handle or more likely to be driving faster). Or make your car more of a theft target since thieves will want those parts. Which is all of them, really.
At any rate, if you don't declare accessories (i.e. non-mechanical stuff) then even if you get paid out they won't factor their value into the payout figure. Because, as far as they're concerned, you never had them.
This is an insurance question,
with the modifications of the following
1. Pod FIlters
2. Z-tube
3. Grounding Kit
4. Plenum Spacers
5. Strut brace
You should, if you want to claim the modification costs back when the worst possible thing happen to your car. I am not sure if different insurers have different ways to insuring the modified cars.
I am with HBF. When I called them up 2 years ago about insuring my bodykit, etc, they said I can insure up to about AU$8500 (Which is about 25% of the total agreed insured value of my car.).
So looks like I will be changing the insurer when I past AU$8500 mark in modifications, if my policy stays unchange.
Edited by VNS 24
    • That may not be so tricky with a changeover relay (again, with LED indicator only to reduce load on existing headlight + source)  30 to indicator + globe side 86 and 87 to headlight parker + 87a to original indicator + chassis side 85 to chassis/earth repeat on each corner, sorted, no diode required
    • There might have been some "hard core" decalcification going on in the cells to create that noise As for chargers, I stick all our cars on a trickle charger every few months to "clean out their pipes/cells", the Mrs battery in her Mistsu ASX is still running its OEM from new battery 10 years on, and that thing does alot of short drives, and it can sit around for ages without a good long run
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
