I am now really considering the GTM HKS version Stage 3 supercharger....which should get me an additional increase in HP between 100 to 140 RWKW and put it closer to 260 to 280 RWKW.
If I can get the totally install at 8K I would be happy.....I am being to slowly work on the price....and remember the HKS superchager will only increase RWKW by 60 to 70 HP.
  • 4 weeks later...
Should be interesting to see it all installed as it certainly isn't a kit. Are you a fabricator?
The best bet would be the HKS 3037 kit if you can still find one. Or here is the Greddy twin kit: http://www.ebay.com.au/itm/GReddy-Tuner-Twin-Turbo-Kit-Nissan-350Z-VQ35DE-TD06-20G-/200604249034?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eb4f1ebca#ht_5005wt_905
You will need to build the engine with forged parts to run more than 5 or 6 psi safely though.
Id go for the HKS supercharger kit as below
http://www.nengun.co...gt-supercharger
or the greddy japan twin turbo kit ( im not 100% but i think greddy USA also makes one which isnt exactly the same? )
The main point with the japanese kits is that firstly.. there wont be fitment issues from these brands, it will be like OEM. Secondly there wont be reliability issues from these ones.. they will again be like OEM. Sure the USA kits always give more power, but they dont offer the same reliability and fitment that the jap kits can. Especially in regards to fitment issues due to difference between left and right hand drive models.
Price wise the supercharger will be alot cheaper in regards to initial install as you arent paying for new exhaust components etc. and i would imagine require less work to get them fitted. The complete kit with engine management can be had for around $6500 which leaves you with $1500 for install. Probs better off with the pro kit though which is $1000 cheaper as it doesnt include extra injector ( which is fine but not great ) or ECU which your better off getting something that local tuners use.
Edited by Ben-88
With the SC kit am i still going to have to build the engine with forged parts or can i get away with stock to start with?
Kudos still have one 3037 kit left.
There are a few of us installing it so may as well get the same one so you have more support in getting it on!
I have just invested some $$ in getting a jap to english conversion of the manual done. Isnt perfect english but better than most chinese english instructions !
Well the HKS kit for example is a ready to go bolt on kit with no other requirements if it is run as provided. They only run relatively low boost so they will be fine with stock internals and compression. Obviousley once you start increasing boost you will need to upgrade the rest of the engine to cope better with it. It might be a good idea, at the very least though, to check the tune and A/F ratios etc on a dyno once the install has been done if you buy the complete kit or possibly even get it re-tuned. Its probably tuned for local conditions so things may vary with our fuel, temps etc. over here as well as any other mods you may have so better safe than sorry. Also might be worth a re-tune which should give a bit more power because being a bolt on kit, just like OEM engine management, it will have been tuned with some margin for error since each engine is never identical.
Edited by Ben-88
Thanks for that, my issue atm is that if i get a kit and blow the head off the engine im gona be up the creek as its my only car lol. Im gona do suspension and gearbox (i have an auto so its slugish in the sifts and needs work) 1st then i might look at the SC kit.
A shift kit for the auto is easy enough if you have the RE5, mine is handling tripple the stock torque. There are a few places I could recommend in Melbourne but I don't know of any up in new south sorry.
How would i find out if i have the RE5? and also what is the RE5 lol (feel like a total noob :P im guesing it is the gearbox)
Its the 5 speed auto most of us have. There are a few valve body kits floating around for them but most good automatics places will have worked on them and made their own parts (for Nissan Patrol rock crawlers.)
Scotty<>>>>>>
GTM Motorsports sales them.....and many in the states have used them too
Yep, I have the Transgo one fitted, upgrading the valve body. I also had major slippage so the clutches were upgraded with a full rebuild and high stall converter. It was the first one they had done like it, they had to laser cut the thinner steel plates to fit a few more clutch plates in. It cost $4000 all up around 2 years ago. Now you can probably get it done for half that.
It should handle a fair bit but I am aiming at 350-400awkw through it at perhaps 1400nm and no-one can tell me if it will let go. There aren't that many performance parts out there yet for the RE5 but they are coming.
    • Found the answer: it wont fit without a bit of work- you'd have to change the guards as well
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
