  • Replies 245
Posted Images
Forms have been delayed a couple of weeks. I am going to Temora for meetings with Council etc etc but CAMS have decided they want a track/venue inspection now, which will be in another 2 weeks. The Sup Regs and Entry forms are done, but we can not release them until the Track/venue inspection is done
Thats just another hour and a bit for all the Sydney guys to go, each way. So on Friday its an extra hour, Saturday an extra 2 hours, Sunday another hour.
Over the weekend its at least 4 hours of driving extra just to go to a pub when there's pubs in Temora.
Once we are kicked out, we drink at the accomodation Deca style.
Thats dedicated, awesome to see.
If you get in, want to stay with the skyline guys? How many beds would you need?
thanks Steve-o
wouldn't want to stay anywhere else, only two seats in the malloo ( I reckon he'll want to put that the strip as well, VE series2 with a bit of work ) just me and my bro. cheers.gif
cheers Richard
Spent a few days in TEmora over the weekend smashing out all the usual finer details with the council and the aviation museum there. The whole town is behind the event and all talking about it.
Also found a few things out that have been asked here and on other forums :
1) There is no 98 Octane Fuel in Temora. The nearest is in Wagga. We will have an area set aside for fuel if you if you wish to bring your own and we are speaking with a local BP commercial distributor to see if we can get a mini tanker of Ultimate there for the day.
2) Surface on the runway is excellent. it is fine but coarse, so traction will be excellent. Run off is good as well.
3) Not Nitrous as per CAMS regs
4) You will need to check with where you are staying as to parking for trailers if you are towing your cars. If there is enough interest, we will look at hiring security for the aviation museum so cars/trailers can be parked there for the night.
5) Accomodation is filling VERY fast
thanks Steve-o
cheers Richard
No dramas!
That's all good and well - but considering there are no forms available - It's a bit of a gamble for people coming interstate to book accomm and so on now when we don't even know if we've gained entry to the event...
Not just you spastics from Victoria, we are all in the same boat :(
At least like every other event, the first one runs with hiccups then the rest after there are nice and easy and get better one after the other
eh? fine but coarse? :blink:
sounds good though. I'm very tempted to go but have so much on these next 2 months. :(
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
