I started NISSAN factory ECU tuning from year 2004 include RB25DET.
Cheapest price in Sydney.
NISTUNE PRICE (using nistune software and nistune board)
R32 Z32 $950 R34 stagea silvia $950 R33 $1200 include Z32 ecu.
to include install and fitting nistune board with road tune and dyno tune.
REMAP PRICE (using nistune software and chip)
R33 from $700
to include install and fitting chip and socket (ECU exchange) with road tune and dyno tune.
REMAP AND NISTUNE is same performance.(both NISSAN factory ECU tune)
This price is basic tune only.
Full tune engine is extra.
DYNO CANNOT BE DONE ON SUNDAY- ROAD TUNE ONLY
NISTUNE , Power Fc ,HKS FCON ,and R32 R33(R33 ECU) R34 Stagea Silvia 300ZX daughter board REMAP ECU road tune and dyno tune available in Sydney.
How to tune on road
I will fit wideband air fuel ratio meter(same dyno machine O2 sensor), and lap top computer, Gizzmo KMon Knock Monitor & Analysisor,before we leave the house.
While the customer is driving,I will sit in the passenger with my laptop.
Start with 2nd gear, winding up from 2000rpm-5000rpm to check car condition and datalog.
I will make fuel and timing map then 2nd gear again to check air fuel ratio and engine knock.
After making rough map on 2nd gear, we will go to freeway .With 3rd/4th gear, we will be running on freeway from 2000rpm-3000rpm to check engine response and engine knock.
Then next 3000rpm-4000rpm ,this will be repeated in increments of 1000rpm.If we find flat spot , slow response , laggy,engine knock etc I will fix and tune on freeway.
After that is done, we will go to nearest dyno shop to check power and power curve etc at 4th / 5th gear.If necessary I will adjust fuel and timing map on dyno. We will return via route with small mountains to further check response and power feel.
Also available road tune only or dyno tune only.
Ph 0410490049
e-mail [email protected]
If you are not happy with the performance, I will not charge.
  • 1 month later...
Mail order R33 (R33 ecu use) factory ecu custom remap also R32 R34 Available for other state.
I will remap chips according to your car modifications
price
Std turbo , std AFM , Hiflow fuel pump , std injector R33 $400 ,R34 $500 (R34 will install daughter board. This daughter is able to use nistune and emulator) plus post $20 ecu exchange
Hiflow turbo , Z32 AFM , Hiflow fuel pump , std injector R33 $500 , R34 $600 (R34 will install daughter board. This daughter is able to use nistune and emulator) plus post $20 ecu exchange
  • 2 months later...
I did real time ecu tune (R33 ecu ) Mr David Stankowski drift car in gold cost at 23 July 2011 and he got second place after my tune! PRO TOUR 2011-----Round 4----QLD RACEWAY----Sun july 31
His cars engine is RB25DET std turbo,std AFM,std injector, and my remapped R33 ecu.
http://www.nissansilvia.com/forums/index.php?showtopic=480831&st=0&p=6346004&hl=David%20Stankowski%20&fromsearch=1entry6346004
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
