Hi guys, problem again with my hicas, now it started couple months ago, here and there, now all of a sudden, if I drive it up the shop it's fine, but as soon as I go start it again at the shop the light comes on, seems to be everytime I turn it off and then back on. I have to leave the car a little while and it seems to go away, used to be couple miniutes, now seems longer. Before anyone says search it, I have, doesn't really sum up the problem though. Anyone else have an idea how to deal with it, or anyone know somewhere on Brisbane northside I can get a lockout bar put on so I don't have it anymore. Thanks for your help.
https://www.sau.com.au/forums/topic/362252-hicas-light-again/
  • 3 weeks later...
A lock bar may only solve the problem if the cause is located in the hyd circut concearned, what if it's electrical? or located in pump, sticking valve which in turn causing cavation in pump, could be many causes.
Cant you do a test on it?
try the turn wheel and tap brake peddel thing ,this causes the hicus to do a self test the rear wheels move and all by them selves, when the hicus computer does self test then light on dash flashes a code to tell you if it's found something.
don't ask how, to much info to try and pass on here get/have alook in manual on how to do it and the codes are there also.
Ive done this and it does work its interesting to watch your car moveabout buy its self.
good luck
good luck
All well and good except that R33's have electronic HICAS so it wont be a hyd problem......
more details about the car? Does it have an aftermarket steering wheel?
The diagnostic mode is done by starting the car, turning the wheel left and right 5 times, tapping the brake pedal twice and driving forward about 5-10m and tapping the brake pedal once more (pretty sure thats the full procedure anyway)
Mine would throw up the HICAS light when I Travelled above 80km/h for more then 15mins or so, because I had my steering wheel boss kit on wrong and it wasnt engaging the steering angle sensor properly (Had to much play is the best way to describe it)
Is there anything youve done to the car lately?
  • 4 weeks later...
  • 3 weeks later...
My light came on today after being on the highway for about half an hour at 100kmh but i had no loss of steering. The car has an aftermarket steering wheel with a stupid boss kit and i find it does have quite alot of play so my +1 for dodgy fitment of boss kit.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
