Hey,
I have a 180sx I'm building for track only use with an LSX motor. It has no wiring at all in it, and I am going to wire it up from scratch, but I have found some universal chassis harnesses on the net for sale. Here is the one I'm looking at http://www.summitracing.com/parts/SUM-890021/
Just wondering if any of you guys that have done full chassis harnesses, which route did you go, and any other harnesses that might suit a 180sx better. For the price, a full custom one made from scratch wouldnt be much cheaper, plus the time it takes to make it!!
https://www.sau.com.au/forums/topic/362283-custom-chassis-harness/
I do heaps of them for circuit car builds.
I've tried those universal looms and they never work out as well as a custom made loom.
Everything they use is available in better components and you can integrate the loom into the car properly.
If you have a good electrical understanding it's not hard to nut out what needs to he done.
I usually supply a wiring diagram with cars I build so tracing potential problems down the track is simple for the owner
where are you located?
Thanks Risking. Have you got any good websites where I can purchase auto electrical gear, such as plugs, cable, flasher units, relays, fuse boxes. My local town has a huge mining tax on everything, much cheaper to buy from a major city based company and posted here.
If you wouldn't mind do you think you could please send me a copy of some wiring diagrams via email? Just a basic one, that I can get half an idea from. I can follow diagrams, but from scratch I would not know where to start. Feel free to PM me, thanks
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
