R32-GTST Posted March 13, 2004 Share Posted March 13, 2004 Hi there peeps... Can anyone give guidance and their experiences in making the necessary modifications for registration of R32-GTST under the 15+ import rule. Such mods Prestige Motorsport suggest are: retractable seatbelts for rear seats, sun visors, child restraint points on the rear parcel shelf for cars with rear seats, high level brake light, driver's side mirror to be changed from convex to flat, unleaded fuel filler opening restrictor, side intrusion bars, engineer's certificate, and a new set of tyres if the Japanese tyres are worn out. Where and how have people done these mods and how did they go when having their car inspected at Regency TransSA? Also have people come across any problems when purchasing a import on the net (in particular Prestige Motorsport)? Did you get what you thought you paid for and was their any probs with shipping and DOTARs? Cheers heeps guys! Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/ Share on other sites More sharing options...
Driver Posted March 13, 2004 Share Posted March 13, 2004 i thought the tyres had to be replaced reguardless of condition Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-722247 Share on other sites More sharing options...
ibz23q Posted March 13, 2004 Share Posted March 13, 2004 i thought the tyres had to be replaced reguardless of condition no because this is a 15 year old car if the tyres are worn out than u have to change them. prestige motor sport from wat ive heard are pretty good as in service and they tell ya wats happening hope that helps mate Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-722302 Share on other sites More sharing options...
sean01 Posted March 13, 2004 Share Posted March 13, 2004 I imported an RX7 Series 4 Turbo through mark @ MY Trading. He was a pretty honest guy and guided me through the whole process its fairly straight forward. Just remember, you get what you pay for so pay that little extra for your car otherwise you will enfd up with a POS. Only a few things will need to be changed for a skyline, intrusion bars will most probably be needed and the most costly, CRA 's for the rear seats, dimmer switch, drivers side mirror, fuel restrictor etc... As long as the tyres have suficcient tread you wont have to change them. Shipping and taxes aprrox $2300 on a 390000 yen car. Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-722647 Share on other sites More sharing options...
R32-GTST Posted March 16, 2004 Author Share Posted March 16, 2004 Cheers guys, Is the engineer's certificate only required for the intrusion bars on the 2 front doors... or a certificate for the whole car??? Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-726843 Share on other sites More sharing options...
RussGTR Posted March 16, 2004 Share Posted March 16, 2004 A mate of mine just brought in a modded Cefiro, i believe he only needed an engineers certificate for the intrusion bars (4 on a cefiro), but while he was there he got everything else engineered (full roll cage, bucket seats, body kit, suspension, front mount etc.). Probably worth while. Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-726895 Share on other sites More sharing options...
lwells Posted March 16, 2004 Share Posted March 16, 2004 Cheers guys, Is the engineer's certificate only required for the intrusion bars on the 2 front doors... or a certificate for the whole car??? The whole car. The engineers certificate then allows you to get a blue slip (ie. get number plates) and then do rego. I have a list of places in Sydney as I am importing an R32 GT-R -- but not adeliade I'm afraid. There doesn't seem to be a directory of these workshops so they can be quite hard to find, but Geoff should be able to point you to someone. The cheapest in Sydney is about $1200, the median is about $1500, and the more expensive places about $1800-1900. LW. Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-726965 Share on other sites More sharing options...
RussGTR Posted March 16, 2004 Share Posted March 16, 2004 Iwells, what do you mean by the "whole" car? Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-727011 Share on other sites More sharing options...
lwells Posted March 16, 2004 Share Posted March 16, 2004 Iwells, what do you mean by the "whole" car? As I understand it, all the modifications too the car to comply with the ADRs must be certified by an engineers report. That doesn't mean they have to be installed by an engineer, merely that they have to be present and working when the car is certified. I could be wrong though LW. Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-727018 Share on other sites More sharing options...
RussGTR Posted March 16, 2004 Share Posted March 16, 2004 No worries Iwells, my mate got it engineered after the intrusion bars and before all the other stuff. Maybe it was a bit on the dodge?? My GTRs on the way too, so i guess i'll find out. I intend on using the same guy though because i cant believe the mods that were passed. RTA checked it all out ok too. Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-727043 Share on other sites More sharing options...
R32-GTST Posted March 19, 2004 Author Share Posted March 19, 2004 Prestige Motorsport claim not all states need a engineers certificate.... which states are these??? Also, my R32 GTS-T will be completely stock standard (initially). So does that mean I only need a engineers certificate for the intrusion bars as they are the only mechanical modification done to the vehicle b4 rego??? Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-731377 Share on other sites More sharing options...
lwells Posted March 19, 2004 Share Posted March 19, 2004 Prestige Motorsport claim not all states need a engineers certificate.... which states are these??? I'm guessing here, but WA usually has less restrictive car regulations than the other states... LW. Link to comment https://www.sau.com.au/forums/topic/36230-importing-a-15yr-r32-import/#findComment-731454 Share on other sites More sharing options...
