Hi
I have bought a pair of gtr r33 xenon headlights..i want to fit them to my r33 gtst..the bonnet, gaurds and front bar do not fit the headlights but..does anyone have another way that could be done? would changing to a gtr raidiator bar work?
please help if can
thanks
I think that u need to change guards, bonnet, bar and even the rio on the front Cause being skylines they dont fit each other..... I learned this after i bought a gtr carbon fibre bonnet and it not fitting U wanna buy it ? lol
Want to sell them to me for a song?
It sounds like you've got series 2 R33, cos someone here have one of these on his Series 1 (or 1.5) 33 GTST with stock bonnet, bumper and guards.
Onto a series 1 they bolt straight up.
GTR headlights and S1 GTST head lights are the same.
If they don't fit you have a S2. Unfortunately you have a huge job to make them fit. Should have done some research prior to buying them. I suggest selling them.
S3 xenons are NOT the same. the pickup points on teh bottom are different. there is a change somewhere in the radiator/headlight panels. there is a good 20-25mm difference int he panel->light mounting. next time I get a certain GTR in I will show you.
also make sure the ballasts are there if you do buy them
just had a bit more of a think about it:
OP has a s1or s1.5 therefore:
bonnet,front bumper, radiator/headlight panels need to change it s not a task for the lighthearted.
To make it a bolt on affair yes Chris. We didnt, we modded it.
Hmmm fair enough. I just assumed they were the same given S1 and S2 GTR headlights are the same as S1 GTST headlights and the S3 Xenons don't look any different.
the GTR I am talking about belongs to a customer of mine. car is a s1.5 and the lights S3. top/side mounts line up the bottom inner does not line up at all.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
