Hey guys so i finally got my V35 today and i was just wondering im in sunnybank area i haven't seen many of the V skylines out there so if theres any of you here brisbane area mainly please drop a post might arrange a cruise for the next couple of months
cheers John...
https://www.sau.com.au/forums/topic/362329-v35-skylines/
cheers John...
Hey John, we are down in Mt Warren Park. There is quite a few of us down this way (as Chris Rogers said recently, we are like mushrooms & pop up everywhere!) as I see them up & down the M1 on my daily commute to the city. Quite a few get around the Springwood area & that northern end of the coast. I for one enjoy the cruises & would be keen to meet up with fellow V owners.
Cheers, Andrew
https://www.sau.com.au/forums/topic/362329-v35-skylines/#findComment-5783231
jon,
I am but I don't drive a V35.
most of thecustomers/ people I see through here are 40+. the car I have here now the owner is easily 45.
if you like I can kick them your direction IF you set up a meeting point.
https://www.sau.com.au/forums/topic/362329-v35-skylines/#findComment-5785654
  • 1 month later...
Old Thread resurrection!
My V35 is a few months away (Lands in Australia on July 19 and then has to go through compliance)
but I live on the South side.
Moved here from the Sunshine Coast at the start of the year
When I get it I'm keen for some skid pan or going down to Willowbank
What sort of V did you get Turbotonic?
https://www.sau.com.au/forums/topic/362329-v35-skylines/#findComment-5861501
good to see enthusiastic V35 crowd, i went with a sedan over a coupe because of family i should have bought one years ago tones of power for a natuarlly aspirated VQ35 iove this car
when we get about 10 people atleast will sort out cruises and meets
https://www.sau.com.au/forums/topic/362329-v35-skylines/#findComment-5863236
I will get my V35 sedan soon (as soon as my father stops trying to convince me to buy something else the coot), but I live about 600km's north of Brisbane so I will have to set up in advance to come to any of the cruises etc :( on the upside it will be the ONLY V35 in town.
https://www.sau.com.au/forums/topic/362329-v35-skylines/#findComment-5867072
Any other V's coming along on the Northern Sunny Coast Hinterland Cruise this Sunday? Living at Mt Warren Park it will be an early start to make it to the meet Caboolture meeting point as I am picking up my son from Stafford Heights on the way.
https://www.sau.com.au/forums/topic/362329-v35-skylines/#findComment-5869708
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
