Hi all,
Im getting my r34 gt-t shortly and have future plans for it. My aim is to get around 350kw at the wheels.
Anyway i have already purchased an emanage with software, harnesses etc and im wondering if the emanage is going to do the job and get the results i want. If not ill just have to sell it and get a wolf or PFC
Thanks
Brendan
https://www.sau.com.au/forums/topic/36233-will-the-emanage-hack-it/
If you wany around 350kw .... well dont buy anything now.. get a GTR or put RB26 on it,,, or else u going to pay $$$$$ for it.. trust me...
with all your part below
Parts|- *Greddy*: Full Auto TT + Profec B Spec II + Emanage. *Hybrid*: FMIC. *Apexi*: Power Intake Pod Filter + EL Meter Series2 Boost Guage + N1 Exhaust System. *GFB*: Hybrid BOV. *Sparco*: Accessories. *Whiteline*: Rear Subframe Align Kit.
max u will get is around 250kw max
Guest RedLineGTR
i believe the emanage will hack it but the issue is do u know people that can tune it well??? that is the main problem with some ecus some people cant tune them, i say talk to some preformance shops or dyno tuners etc...see what they have to say. Also good info can be found in the HPI DVD's And HPI Magazines one thier r34 gtt project...unless u have seen them already, they have some good info and came close to your goal of 300rwkw.
Well im planning to do all this over the next yr. My original plans were to only slightly modify it but now i have a better income they changed :rofl:
Im going work out exactly much money ill have over the next year and how im going to spend it.
I was thinking along the lines of a HKS GT3040 as i will eventually get around to getting forged internals.
My car should arrive sometime next month so while i have time on my hands i want to start planning.
No, the E-manage will not hack it.
For the HP you are chasing you will need bigger capacity injectors. E-manage doesn't support this. For what you want, Power FC, Microtech or Wolf are popular choices. Piggybacks & sensor benders rely on the factory ECU which has limitations. A fully programmable standalone is what you need.
Your budget is very optimistic.
that ecu will cost you say minimum $1200 (used price)
Tuning & AFM/MAP sensor $600
Injectors say $1200-2000+ if you're lucky enough to find bigass injectors to suit the Neo (R33 RB25 injectors are different and far more common)
Brakes & supension will need upgrading to make it tractable at that sort of power. $2000+
Fuel pump of course $300
Forged & balanced internals + gaskets/bearings etc. if you expect it to last beyond a week $2000+
A Twin plate clutch $1200 (used price).
Labour (unless you can do it all yourself) $2000+
There's 10 large - before you have a turbo, manifold, wastegate, front exhaust section & new undies.
you CAN get a complete RB26 for $6000. The GT-t gearbox has the same tough internals as the GTR. ECU's are cheap as. I would recommend consulting a specialist workshop & telling them exactly how you wish to use the vehicle. circuit/drag/motorkhana/street/or a bit of any or all.
You'll still need to budget for suspension & braking mods of course, and you'll want to rebuild the turbos with inconel wheels (a la nismo) but a lot less dicking around altogether,
& you might be able to afford those new undies...
mmmkay ??
The E-manage does enable you to use higher flowing injectors. Up to 150% of original injector capacity stated by GReddy but in reality they do support larger than that limit.
For the money the E-manage is a great bit of kit and very easy to program.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
