Hi all,
Im getting my r34 gt-t shortly and have future plans for it. My aim is to get around 350kw at the wheels.
Anyway i have already purchased an emanage with software, harnesses etc and im wondering if the emanage is going to do the job and get the results i want. If not ill just have to sell it and get a wolf or PFC
Thanks
Brendan
https://www.sau.com.au/forums/topic/36233-will-the-emanage-hack-it/
If you wany around 350kw .... well dont buy anything now.. get a GTR or put RB26 on it,,, or else u going to pay $$$$$ for it.. trust me...
with all your part below
Parts|- *Greddy*: Full Auto TT + Profec B Spec II + Emanage. *Hybrid*: FMIC. *Apexi*: Power Intake Pod Filter + EL Meter Series2 Boost Guage + N1 Exhaust System. *GFB*: Hybrid BOV. *Sparco*: Accessories. *Whiteline*: Rear Subframe Align Kit.
max u will get is around 250kw max
Guest RedLineGTR
i believe the emanage will hack it but the issue is do u know people that can tune it well??? that is the main problem with some ecus some people cant tune them, i say talk to some preformance shops or dyno tuners etc...see what they have to say. Also good info can be found in the HPI DVD's And HPI Magazines one thier r34 gtt project...unless u have seen them already, they have some good info and came close to your goal of 300rwkw.
Well im planning to do all this over the next yr. My original plans were to only slightly modify it but now i have a better income they changed :rofl:
Im going work out exactly much money ill have over the next year and how im going to spend it.
I was thinking along the lines of a HKS GT3040 as i will eventually get around to getting forged internals.
My car should arrive sometime next month so while i have time on my hands i want to start planning.
No, the E-manage will not hack it.
For the HP you are chasing you will need bigger capacity injectors. E-manage doesn't support this. For what you want, Power FC, Microtech or Wolf are popular choices. Piggybacks & sensor benders rely on the factory ECU which has limitations. A fully programmable standalone is what you need.
Your budget is very optimistic.
that ecu will cost you say minimum $1200 (used price)
Tuning & AFM/MAP sensor $600
Injectors say $1200-2000+ if you're lucky enough to find bigass injectors to suit the Neo (R33 RB25 injectors are different and far more common)
Brakes & supension will need upgrading to make it tractable at that sort of power. $2000+
Fuel pump of course $300
Forged & balanced internals + gaskets/bearings etc. if you expect it to last beyond a week $2000+
A Twin plate clutch $1200 (used price).
Labour (unless you can do it all yourself) $2000+
There's 10 large - before you have a turbo, manifold, wastegate, front exhaust section & new undies.
you CAN get a complete RB26 for $6000. The GT-t gearbox has the same tough internals as the GTR. ECU's are cheap as. I would recommend consulting a specialist workshop & telling them exactly how you wish to use the vehicle. circuit/drag/motorkhana/street/or a bit of any or all.
You'll still need to budget for suspension & braking mods of course, and you'll want to rebuild the turbos with inconel wheels (a la nismo) but a lot less dicking around altogether,
& you might be able to afford those new undies...
mmmkay ??
The E-manage does enable you to use higher flowing injectors. Up to 150% of original injector capacity stated by GReddy but in reality they do support larger than that limit.
For the money the E-manage is a great bit of kit and very easy to program.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
