Hi all,
Im getting my r34 gt-t shortly and have future plans for it. My aim is to get around 350kw at the wheels.
Anyway i have already purchased an emanage with software, harnesses etc and im wondering if the emanage is going to do the job and get the results i want. If not ill just have to sell it and get a wolf or PFC
Thanks
Brendan
https://www.sau.com.au/forums/topic/36233-will-the-emanage-hack-it/
If you wany around 350kw .... well dont buy anything now.. get a GTR or put RB26 on it,,, or else u going to pay $$$$$ for it.. trust me...
with all your part below
Parts|- *Greddy*: Full Auto TT + Profec B Spec II + Emanage. *Hybrid*: FMIC. *Apexi*: Power Intake Pod Filter + EL Meter Series2 Boost Guage + N1 Exhaust System. *GFB*: Hybrid BOV. *Sparco*: Accessories. *Whiteline*: Rear Subframe Align Kit.
max u will get is around 250kw max
Guest RedLineGTR
i believe the emanage will hack it but the issue is do u know people that can tune it well??? that is the main problem with some ecus some people cant tune them, i say talk to some preformance shops or dyno tuners etc...see what they have to say. Also good info can be found in the HPI DVD's And HPI Magazines one thier r34 gtt project...unless u have seen them already, they have some good info and came close to your goal of 300rwkw.
Well im planning to do all this over the next yr. My original plans were to only slightly modify it but now i have a better income they changed :rofl:
Im going work out exactly much money ill have over the next year and how im going to spend it.
I was thinking along the lines of a HKS GT3040 as i will eventually get around to getting forged internals.
My car should arrive sometime next month so while i have time on my hands i want to start planning.
No, the E-manage will not hack it.
For the HP you are chasing you will need bigger capacity injectors. E-manage doesn't support this. For what you want, Power FC, Microtech or Wolf are popular choices. Piggybacks & sensor benders rely on the factory ECU which has limitations. A fully programmable standalone is what you need.
Your budget is very optimistic.
that ecu will cost you say minimum $1200 (used price)
Tuning & AFM/MAP sensor $600
Injectors say $1200-2000+ if you're lucky enough to find bigass injectors to suit the Neo (R33 RB25 injectors are different and far more common)
Brakes & supension will need upgrading to make it tractable at that sort of power. $2000+
Fuel pump of course $300
Forged & balanced internals + gaskets/bearings etc. if you expect it to last beyond a week $2000+
A Twin plate clutch $1200 (used price).
Labour (unless you can do it all yourself) $2000+
There's 10 large - before you have a turbo, manifold, wastegate, front exhaust section & new undies.
you CAN get a complete RB26 for $6000. The GT-t gearbox has the same tough internals as the GTR. ECU's are cheap as. I would recommend consulting a specialist workshop & telling them exactly how you wish to use the vehicle. circuit/drag/motorkhana/street/or a bit of any or all.
You'll still need to budget for suspension & braking mods of course, and you'll want to rebuild the turbos with inconel wheels (a la nismo) but a lot less dicking around altogether,
& you might be able to afford those new undies...
mmmkay ??
The E-manage does enable you to use higher flowing injectors. Up to 150% of original injector capacity stated by GReddy but in reality they do support larger than that limit.
For the money the E-manage is a great bit of kit and very easy to program.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
