Hey All,
Just recently got and installed a Greddy (REAL branded not fake) Type S bov (Plumb back). After the install I went for a quick spin to test for the "fluttering" to see if I had to adjust the top bolt. I then noticed how "fast" and quick it was pulling. I was getting up into 15-18psi. I have an upgraded turbo, not the factory installed so I wasn't too stressed but kept off the WOT till I got home. I adjusted my MBC which is a TurboTech so it would be on low boost (previously set at around 13psi for my recent tune). Went for another spin, still no luck. Just hits the high boost and looks like it'll keep going.
I have since then, put the stock one back on and its all back to normal... Only getting up to 8psi of boost.
Does anyone have any thoughts? or had one previously installed to shed some light? Also if I've left anything out, let me know.
Sorry for the story, thanks for reading.
Cheers
https://www.sau.com.au/forums/topic/362331-new-bov-causes-unlimited-boost/
the only thing that causes unlimited boost is the actuator not opening
this occurs if the actuator has no boost signal
ie the vac line is blocked, leads no where or has no manifold pressure signal
a broken BOV, a blocked BOV or a faulty BOV has no capacity to cause unlimited boost
Thanks for the fast reply Paul. I thought it may have been one of my vac lines but I checked all them out. Not to mention when I put the stock BOV back on, no problems. Went back to normal. Maybe I'll double check everything tomoz after work. Thanks for the input mate.
Did you modify your stock bov to make it flutter before? I have seen people block the hose between the manifold and bov to make it flutter.. Only problem is it creates a boost leak, lack in response etc. So if you put a new properly set up bov it would increase response/boost etc...
where is your turbotech getting it's pressure feed from? some people tee off the bov vaccum hose. not a smart way to do it. but if you have removed this feed to the turbotech somehow along the way, that would also cause unlimited boost.
Cheers for the replies guys. I never had my stock one set for "flutter". It was always and still is re-circ. I've just checked my turbotech boost controller and the bottom line that is suppose to be pressure seem to be vac. I removed the pipe while the car was running and its "sucking" the air. So thats "VAC" yeh? The feed came from the carbon canister (thicker line).
I've now put the bottom line to the turbo housing, which has a outlet that was first joined to the actuator when I first got the new turbo. I assume that this will be an good "pressured" source?
Please let me know if i've done anything spastic? Also why wouldn't the turbo be unlimited with the the stock BOV? Would it be because it leaks at a certain PSI?
Cheers for the help guys.
Edited by skeg_man
yeah the line off the turbo is a good one for the feed to the mbc. with the turbotech, pressure goes in to the straight end, and the nipple coming off the side goes to the actuator.
there shouldnt be any difference in boost levels between two working bovs, but if your stock one was absolutley stuffed, maybe. it would have to have been basically totally open all the time and recircing pressure back into the system under boost. i guess it's possible.
Cool cool. It always seem to work. Like releasing the pressure making the "swoosh" sound. Who knows.
Was the line i was talking about a "VAC" line? the one from the carbon canister?
Cheers again for the help.
sorry dude, i just saw your PM. i have replied in detail.
it looks like you were using the turbotech, and still had your stock solenoid hooked up as well. you need to disconnect your solenoid.
test your actuator on it's own, then if that works ok, hook up the turbotech, and hopefully it will all be good.
it's all explained in the PM
@ Adzmx - Unsure what you mean mate?
Anyways, found out that I had a faulty actuator. So now i've upgraded to a HKS. Waiting for it to come. So i'll keep everyone posted. Anyone want to buy a BOV? lol.
Cheers again all.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
