Hey All,
Just recently got and installed a Greddy (REAL branded not fake) Type S bov (Plumb back). After the install I went for a quick spin to test for the "fluttering" to see if I had to adjust the top bolt. I then noticed how "fast" and quick it was pulling. I was getting up into 15-18psi. I have an upgraded turbo, not the factory installed so I wasn't too stressed but kept off the WOT till I got home. I adjusted my MBC which is a TurboTech so it would be on low boost (previously set at around 13psi for my recent tune). Went for another spin, still no luck. Just hits the high boost and looks like it'll keep going.
I have since then, put the stock one back on and its all back to normal... Only getting up to 8psi of boost.
Does anyone have any thoughts? or had one previously installed to shed some light? Also if I've left anything out, let me know.
Sorry for the story, thanks for reading.
Cheers
https://www.sau.com.au/forums/topic/362331-new-bov-causes-unlimited-boost/
the only thing that causes unlimited boost is the actuator not opening
this occurs if the actuator has no boost signal
ie the vac line is blocked, leads no where or has no manifold pressure signal
a broken BOV, a blocked BOV or a faulty BOV has no capacity to cause unlimited boost
Thanks for the fast reply Paul. I thought it may have been one of my vac lines but I checked all them out. Not to mention when I put the stock BOV back on, no problems. Went back to normal. Maybe I'll double check everything tomoz after work. Thanks for the input mate.
Did you modify your stock bov to make it flutter before? I have seen people block the hose between the manifold and bov to make it flutter.. Only problem is it creates a boost leak, lack in response etc. So if you put a new properly set up bov it would increase response/boost etc...
where is your turbotech getting it's pressure feed from? some people tee off the bov vaccum hose. not a smart way to do it. but if you have removed this feed to the turbotech somehow along the way, that would also cause unlimited boost.
Cheers for the replies guys. I never had my stock one set for "flutter". It was always and still is re-circ. I've just checked my turbotech boost controller and the bottom line that is suppose to be pressure seem to be vac. I removed the pipe while the car was running and its "sucking" the air. So thats "VAC" yeh? The feed came from the carbon canister (thicker line).
I've now put the bottom line to the turbo housing, which has a outlet that was first joined to the actuator when I first got the new turbo. I assume that this will be an good "pressured" source?
Please let me know if i've done anything spastic? Also why wouldn't the turbo be unlimited with the the stock BOV? Would it be because it leaks at a certain PSI?
Cheers for the help guys.
Edited by skeg_man
yeah the line off the turbo is a good one for the feed to the mbc. with the turbotech, pressure goes in to the straight end, and the nipple coming off the side goes to the actuator.
there shouldnt be any difference in boost levels between two working bovs, but if your stock one was absolutley stuffed, maybe. it would have to have been basically totally open all the time and recircing pressure back into the system under boost. i guess it's possible.
Cool cool. It always seem to work. Like releasing the pressure making the "swoosh" sound. Who knows.
Was the line i was talking about a "VAC" line? the one from the carbon canister?
Cheers again for the help.
sorry dude, i just saw your PM. i have replied in detail.
it looks like you were using the turbotech, and still had your stock solenoid hooked up as well. you need to disconnect your solenoid.
test your actuator on it's own, then if that works ok, hook up the turbotech, and hopefully it will all be good.
it's all explained in the PM
@ Adzmx - Unsure what you mean mate?
Anyways, found out that I had a faulty actuator. So now i've upgraded to a HKS. Waiting for it to come. So i'll keep everyone posted. Anyone want to buy a BOV? lol.
Cheers again all.
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
