Hi, Wondering if anyone on here can point me in the direction of someone with a scan tool to plug into my V35 sedan?
Air bag light has started to flash and the usual reset only lasts for a day.
My local Nissan dealer usually wont touch imports.
Thanks in advance.
https://www.sau.com.au/forums/topic/362340-scan-tool-v35/
Hi Geoff this is the wrong place to be asking such advice. Post a thread in the V35 section - and in fact you will already find a topic there on it.
But I would take it to Main North Nissan if I were you - pretty sure they will service the V35 since it is so similar to the 350Z.
BTW saw your V35 in Nuri a few weeks back parked in the carpark at the park with the train in it opposite BP/Subway. Looked around for you, but couldn't find you.
https://www.sau.com.au/forums/topic/362340-scan-tool-v35/#findComment-5782483
Thanks Andrew,
Was hoping that there may have been someone else other than a dealer that could help.
Anyone with a Carman or Launch scanner could do the job as well.
Spotted your car leaving not long after I arrived in my Ute. Missus drives the 35.
Cheers
Geoff
https://www.sau.com.au/forums/topic/362340-scan-tool-v35/#findComment-5782526
andrew,
he's already asked me about it. told him what to look for as well. its case of finding someone dwon there with a carmen or launch to read the thing. I'm 2'5 hrs away by plane and I'm not heading that way anytime soon.
who does your svc work? (they may be able to help him :) )
in general nissan is nissan. the diagnostics haven't really changed (unless we are talking C3) on any of them.
https://www.sau.com.au/forums/topic/362340-scan-tool-v35/#findComment-5782530
I do all my own work on the car Chris - a mechanic of any variety has not touched the thing yet.
As I said go to Main North Nissan, Craig in the spare parts division is an import supporter (he used to help me out on spares for my R34 all the time no problems), and they are an SAU:SA club sponsor (so if you joined up you would get 10% off too), so I would definitely try there Geoff.
https://www.sau.com.au/forums/topic/362340-scan-tool-v35/#findComment-5782570
  • 2 months later...
The common problem with airbag light flashing is loss of contact in yellow conectors below passenger or driver seats. There are two of them for two safety devices that related to SRS system (in accident they will brake a lower part of seat to keep you down) Fix them and reset SRS by pedal.
http://history.nissa...FETY/index.html
http://history.nissa...MAIN/index.html
http://history.nissa...XTER/main1.html
Main North Nissan refuses to service V35 and does not matter who are you and where from.
Edited by Nicko_2010
https://www.sau.com.au/forums/topic/362340-scan-tool-v35/#findComment-5887191
"CAS804"..... as basic as they come
If you have an iphone or ipad...... buy the OBDII WIFI connector and download one of the OBD2 apps for realtime diagnostics :)
I did, it doesnt work unfortunately
could not connect with ECU
https://www.sau.com.au/forums/topic/362340-scan-tool-v35/#findComment-5900676
which ABD adapter do you have?
The Kiwi PLX one has videos being used on a G35 on YouTube, and it supports both OBDII and CAN, which our car needs. I have been looking at getting one of these for some time.
https://www.sau.com.au/forums/topic/362340-scan-tool-v35/#findComment-5900741
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
