I don't think that will be doing anything, but I'm not totally sure how these controllers work. I would think that an earth is an earth, so splicing into that wire and earthing it again wouldn't do anything in my mind.
Ok, so i re-grounded it, and it works better.
However!!!
I have realised that whenever i get to about a quarter (or below) of fuel, my car won't bloody start up. Took me so long to get it to fire up.
I turn the key ON and i hear the relay click, which means the problem is between the relay and the pump, correct?
The strainer that came with the walbro pump is quite a bit shorter than the original stock one. Was I supposed to re-use the stock strainer, or use the provided one?
Why I ask, is that I believe that the strainer I'm using sits a lot higher than the original one, and therefore is not "straining" any fuel because it won't reach the fuel down the bottom of the tank when i get low. When i crank the engine at low fuel level, I can hear the pump trying to do something, but the car just won't fire up.
Yeh when you install it you should hold the new pump next to the old pump in the cradle and try to get it to sit in exactly the same place with the strainer in the same place. I am using the little short sock, but I don't have any problems with fuel pick up.
I don't know how much that has to do with your starting issues though. If your pump isn't sitting in the fuel then your car isn't going to start no matter how many times you crank it. Try pulling the entry hose (the one coming from the fuel filter) to the rail off and priming the pump for a quick second. If any fuel comes out then you know that the starting issue isn't because of the fuel pump not sitting in the fuel.
I have the pump sitting in the same position as stock, but the sock itself doesn't reach as low as the stock one.
I filled up my tank today and it starts up fine after i prime the pump so I won't be able to test the fuel filter hose removal until it happens again i guess :\
hi guys just about to do my fuel pump rewiring.
it seems the previes owner has already done it. the postie wire has been chopped and joined.
the fuel pump is getting 13.2 volts and at the battery its 14.2 !
any ideas ?
Postie wire?
Could be a couple of things with that voltage. Firstly the pump may not have been rewired. You better trace all the wiring and see where it goes. Shouldn't be hard, you should have some decent sized (8ga minimum) cable running from the battery to a relay somewhere. Which leads to the second possibility. If the previous owner has rewired the pump but hasn't used sufficiently sized cable, you could be getting a considerable volt drop between the battery and the pump. In which case you should rewire it all again properly. You could also have a poor earth, but I doubt that will be the case.
If you're unsure, take some photos of the wiring and fuel pump area and I'll try to help you out :thumbsup:
3 black and yellow wires going into one black and yellow wire leading into the fuel pump.
yeh i noticed 3 positive wires, which merge into 1 which go to the fuel pump. I cut the single wire closest to the fuel pump, and didn't touch the 3 separate black and yellow wires.
How do remove the bracket that holds the fuel pump ? Or do just pull on fuel pump and it comes off ?
all you have to do is rich into the fuel tank after you take the assembly off the top, and pull it up and out. The pump assembly just slides onto a mount inside the fuel tank, so no need to use any tools.
  • 4 months later...
I cannot stress the importance of doing this, recently upgraded to a Walbro GSS342 using the stock wiring and the car drove like poo and stalled on me a few times. After the wiring upgrade it's all back to normal :)
  • 7 months later...
Installed my walbro gss342 pump and re/wired. Took her round the block for a spin and she loves it ?? tho I can't hear any buzzing noise? And She seems to be running correctly? Relays clicking and all.
I don't hear mine unless I've been driving around for a while.
And even then, it's only when i dont have music in the car lol.
You'll notice it when you're in the garage though (well i do) :)
As long as it's all working, then no worries!
  • 1 month later...
Late reply but yeah since IV installed it I have had no dramas what so ever :)
  • 5 years later...
On 9/19/2020 at 6:40 PM, dyl33 said:
just to clarify because Step 11. is confusing
The negative wire gets cut, fuel pump end goes to chassis earth.
The other end ecu, goes to pin 86?
Becuase step 11 says tape/cap off ecu end???
Like this
Hey Dylan,
The Green/White from the ECU remains cut/taped off. The Green/White from the Fuel Pump is to be connected to the 8GA Black Negative Cable and the remaining pin (86) is also to be connected to the 8GA Black Negative Cable. I used a piggy back connector on the Fuel Pump Negative Green/White to the 8GA Black Negative Cable so I could connect the remaining pin (86) to the piggy back connector (Green/White Fuel Pump to 8GA Black Negative Cable) to be grounded. I recommend using the negative battery terminal.
I hope this further explanation makes sense. I can provide a photo of my wiring if you are still unsure.
Piggyback Spade: https://www.jaycar.com.au/piggy-back-female-spade-red-pkt-8-self-sealing-quick-connectors/p/PT4810
Edited by Ravskie
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
