Hey peeps,
I'm just after a quick answer on this as I just came inside from ripping more stuff out of the car and I got thinking about my wheels.
I have lmgt2 rims which are 17 x 9 +38 on the rears and 17 x 8 + 35 (I think) on the fronts.
Would the rear size with the + 38 offset fit on the fronts without guard rolling etc???
Would like a bit more dish up front and the same size all round of possible.
Ta
could go down to 225/235 on the 9" easily.
i have driven with my 18 x 9.5J offset +25 on the front of my GTT before and it was sweet...although i have had a bit of guard work and i wasn't executing hairpin corners at great speed on bumpy roads so i didnt really test it.
wait till your 255's are worn out than get a more stretched fitment (get a tyre place that will let you try on a couple of different size tyres and go for a drive) and see how it goes.
Im running 18 x 8.5 +29 on the front, which would work out to be not that different than your rears. Front guards have been significantly rolled.
deff put some pics up when fitted will look very nice
they were *sniff* 18x9.5+25 all round (flush-ish)
currently rolling on 17x9.5+17 all round (10mm poke)
new rims on order are 17x9+12 fr 18x9.5+12 r ;)
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
