These are all the same set of wheels.
The above posts is evidence that not all Te37's have Volk Racing etc written around the outside face - research that could eaisly have been done via a simple google image search!
If you have any Questions please PM so it does not cause confusion like above ^^
I think im just going to keep these - not worth the hassle.
Thanks
  • Replies 70
Posted Images
Thanks Tomek - These are cheap!
To replace these I would have to pay upwards AND over $3k.
Someone will see the value in these wheels and grab themselves a bargin.
Please be in a position to purchase these wheels AT the price listed before inquiry (Saves your time - and mine)
BUMP
Why are they the wrong offset?
+12 is a common offset for a GTR (R33, R34)
ONLY interested parties please comment in my thread.
For those interested +12 or +22 is a common offset for a GTR R33 and R34 with 9.5inch wheel - PERSONAL preference as to how agressive you want to go!
Thanks
Edited by Buildn
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
    • That's the one I have in my R32. There isn't a bigger battery that will fit an R32.
    • Not sure what you mean haha. That one doesn't fit mine but when I get sick of my one I'll get a standard one. I just gotta find a way to make it fit cause some shit is in the way.
    • https://www.supercheapauto.com.au/p/century-century-ultra-hi-performance-4wd-battery-ns70x-mf/602477.html MF for Muthaf*kka
