These are all the same set of wheels.
The above posts is evidence that not all Te37's have Volk Racing etc written around the outside face - research that could eaisly have been done via a simple google image search!
If you have any Questions please PM so it does not cause confusion like above ^^
I think im just going to keep these - not worth the hassle.
Thanks
  • Replies 70
Posted Images
Thanks Tomek - These are cheap!
To replace these I would have to pay upwards AND over $3k.
Someone will see the value in these wheels and grab themselves a bargin.
Please be in a position to purchase these wheels AT the price listed before inquiry (Saves your time - and mine)
BUMP
Why are they the wrong offset?
+12 is a common offset for a GTR (R33, R34)
ONLY interested parties please comment in my thread.
For those interested +12 or +22 is a common offset for a GTR R33 and R34 with 9.5inch wheel - PERSONAL preference as to how agressive you want to go!
Thanks
Edited by Buildn
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
